HKS Silent?
Old Nov 14, 2011 | 09:49 AM
LisbonsG35's Avatar
sounds just fine, i had this exhaust and megan resonated tp's mine was way louder and deeper due to the test pipes, but with stock cats... yeah sounds normal.
Old Nov 14, 2011 | 12:25 PM
Baliztik's Avatar
Originally Posted by gary c
I wouldn't install any exhaust system without gaskets, surprised yours sounds soo good. You mentioned y-pipe the HKS system doesn't have one, it's a cat-back system. Before installing did you check the crossover to see if there was the dreaded restriction HKS is now famous for? HFCs or ART pipes will change the way your coupe sounds, it's just a matter of how illegal you want to be...
Gary
How would I go about checking the crossover?
Old Nov 14, 2011 | 01:31 PM
Lone Wolf's Avatar
Disconnect the mid piping from the H-pipe section and shine a flashlight into the H-pipe section. I imagine that if you had the a little bit of crossover pipe in the path of exhaust flow that it wouldn't make a night and day difference in how loud it would be.
Old Nov 15, 2011 | 12:02 AM
Baliztik's Avatar
But there's no way to fix this issue is there. Other than having piping made.
Old Nov 15, 2011 | 01:58 AM
Lone Wolf's Avatar
If it's the crossover problem you could have that section welded out for a Maganaflow X-pipe section. If it is just some sort of debris by chance I'm sure you could get it out.
Old Nov 15, 2011 | 09:55 AM
herrschaft's Avatar
Other mods? An intake + HFC/TP will make it louder.
I didn't do any mods to my HKS exhaust and it has always been loud on my car. My first configuration was CAI + HKS, not too loud but louder then stock. Then added headers and HFC's which really opened it up, still wish I had the sound of that setup. Currently I'm running straight pipes and its definitely noisy.
Old Nov 15, 2011 | 11:04 AM
gary c's Avatar
The crossover restriction in my HKS system was over an inch, in a 2.5" pipe that's major in my book. Not to mention it made a weird noise at WOT! The Magnflow x-pipe was the answer but correct installation requires a talented muffler mechanic...like mine!
Gary
Old Nov 15, 2011 | 11:28 PM
Baliztik's Avatar
I have the Stillen Z tube already installed and I definitely hear it over the exhaust. My exhaust is really hard to hear when I drive. I'm going to get a video of a drive by and in cabin. By the way I remember it being much more crisp. The exhaust note I hear now almost sounds muffled, or... I don't know it just doesn't sound great. I am disappointed for sure.
Gary
The x pipe is a replacement for part of the h pipe? Maybe just have custom straight pipes made? Do any of you have a before / after of the X pipe installation (video / audio / pictures)?
Old Nov 16, 2011 | 03:05 AM
threatcon07's Avatar
I have an HKS also, sounds exactly how mine sounded (before I supercharged).
Crisci33
Jun 29, 2017 08:31 AM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
