paint peels off interior door panel
Old Nov 16, 2011 | 09:36 AM
wstalker's Avatar
Has anyone else had this problem? I have an 07 g35 and the little pocket on the door panel which you would grab from the inside to close your door has very soft paint...at first I figured my nails were not trimmed well, but you can just scrape that paint off with your fingernail anywhere....any solutions?
Old Nov 16, 2011 | 11:20 AM
bluedevils95's Avatar
that is not paint, that is that rubber texture crap. What i did is sanded mine down and gave it to the paint shop to color match my car. I have the 2nd gen sedan but this all works the same. I think you should do the same thing.
Old Nov 16, 2011 | 11:32 AM
wstalker's Avatar
were you able to just pry it off....remove all the switches...and take it to your paint shop...should be easy to sand
Old Nov 16, 2011 | 10:02 PM
infinitidude's Avatar
Absolutely guys this is a common problem. I replace probably 10-15 of these a month,they changed them in 2009 and no longer put the rubberized coating on them. Also be very careful or the coating around the steering wheel switches will do the same thing. Hope this helps guys...
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
rsingerG35
Interior
Aug 13, 2015 05:01 PM
will091195
Jul 27, 2015 09:19 PM
emorehs
Jul 17, 2015 09:45 AM
