Power Steering stiff? Need help, please.
Old Nov 25, 2011 | 01:01 AM
aRT13's Avatar
Hey guys, it's been a while since I posted on here, but I've been having a problem with my steering feeling quite stiffer than usual and I need some assistance, please.
Quick and to the point, I had my car serviced at EZ Lube a couple of months ago (I know.. ) but I was really ill at the time from a medical condition and honestly, just wanted to get an oil change asap, but thought what the heck, i'll have them do the power steering svc, too. Well, it turns out they used "standard power steering fluid".. I did not know then that I had to use Dexron III trans fluid =/ (I just learned of this in the past few days as I was researching related problems online).
So, now, a couple months later, my steering is beginning to be stiff as hell.
Question:
What the heck should I do? Get a power steering flush, obviously, right? Is it possible I did any damage to my power steering pump from having it like this for so long? I just noticed the stiffness maybe within the past month and I feel that it's definitely not easy to turn my steering wheel anymore. =/
Please help.
Thanx!!
-artie
Old Nov 25, 2011 | 01:53 AM
hurleyguys's Avatar
maybe hit the gym??
no but seriously bump for answers.
Old Nov 25, 2011 | 09:30 AM
HYDRUS's Avatar
Same think happened to me minus the quickie lube. Its was my own temporary stupidity who forgot it too auto tranny fluid lol. Got a flush got better but not good enough so just got a new pump.
Old Nov 26, 2011 | 04:55 AM
aRT13's Avatar
Thanks man. Do you know how much the pumps go for? I heard about $130? Sounds accurate? Thanks again.
Old Nov 26, 2011 | 05:17 AM
faiz23's Avatar
Stop flipping out it is just a car and you will be fine. Stop letting others work on your car and do it your self. Pickup 2 bottles of Mobil 1 ATF fluid and a turkey baster and flush out 2 qts of power steering fluid for 97% new fluid. I would do a full swap of fluid and drive it around 5 miles and then come back and redo the process till you run out of new fluid.
http://gshack.org/?p=272
https://g35driver.com/forums/v36-diy...id-change.html
Old Nov 26, 2011 | 06:58 AM
Blue Dream's Avatar
I drove ttrank's car solo
A friend of mine is a master tech for Infiniti and he recommends using actual power steering fluid instead of tranny fluid. His point was that PS fluid contains lubricants and other wear additives specific to the PS system that tranny fluid doesn't and is better for the operation and longevity of the system.
Just a thought...........
Old Nov 26, 2011 | 11:44 PM
westbank23's Avatar
^^^Can someone back that claim up?
I flushed my power steering fluid and im useing mobil one ATF in it now.
Just wanna make sure it's safe
Old Nov 29, 2011 | 02:59 AM
aRT13's Avatar
Thumbs up
Yeah, this I could do. A lot of the maintenance stuff I can't do, because I'm physically disabled, so some things are more difficult than others for me, haha. But, thanks for the info and the links. I appreciate it.
Old Dec 13, 2011 | 07:25 PM
ArkansasG35COUPE's Avatar
Did the power steering fluid swap work? I have the same issues with my G. I swapped the fluid with fresh, but have not noticed anything...
Old Dec 13, 2011 | 07:36 PM
g35sleeper123's Avatar
I went through this problem on a m3 and i just flushed out the fluid and replaced it a couple of times and was all good
Old Dec 27, 2011 | 07:42 PM
nanotech's Avatar
Thanks guys for all the posts... I had the same problem!
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
zcherub
Sep 10, 2015 12:03 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
spanky99l
Sep 7, 2015 12:46 AM
Kicknshift
Sep 3, 2015 09:35 AM
