1in drop help!!
Old Dec 5, 2011 | 09:31 AM
g35915's Avatar
1in drop help!!
im trying to get a 1in drop or lil less not trying to have camber issues just trying to close up some of the wheel gap and suggestions?? think h tech 350z or hotchiks?? trying to improve handling a lil too ?? thnx for the help
Old Dec 5, 2011 | 09:38 AM
redpearl99's Avatar
please use the search function before making a new thread. this has been covered 100000 times
Old Dec 5, 2011 | 09:40 AM
bluedevils95's Avatar
Is there a 1in drop? I know 1 1/4 and then your going to need a camber kit to fix the rears.
Old Dec 5, 2011 | 01:45 PM
R10T_x's Avatar
Get htechs and you dont have to worry about buying a camber kit even tho thats a pretty weak drop...
Old Dec 5, 2011 | 02:23 PM
g35915's Avatar
what about eibach pro kit ?i just want a 1in heard those are good but sometime people get 1.5
Old Dec 5, 2011 | 03:36 PM
irishsig's Avatar
Most likely you'll be ok with either 350Z h-techs or eibachs.
Most people are still in spec with that small of a drop.
There are some instances where people have needed to get camber kits in order to get back into spec, but it is not that common of an issue with the springs mentioned above.
Old Dec 5, 2011 | 03:40 PM
SDGenius's Avatar
the coupe has camber issues @ stock height, i don't know what your worried about. just get a camber kit then close the gap for real
Old Dec 5, 2011 | 04:28 PM
Dragon Ninja's Avatar
If u want to improve ur handling save up and get coilovers with rear camber kit. If u still want more get strut bars front n rear. Search is ur friend
Old Dec 5, 2011 | 10:57 PM
g35915's Avatar
hmm im thinking the eibach i really dont want a camber kit right now this weeks my bday and im trying to choose between the eibachs or a godspeed hks replica lol
Old Dec 5, 2011 | 11:03 PM
moto_za's Avatar
i just got the eibach pro kit and really like them. perfect drop imo
Old Dec 5, 2011 | 11:04 PM
g35915's Avatar
hows the ride ?? and any camber issues ??
Old Dec 5, 2011 | 11:08 PM
Jairen's Avatar
I was barely in spec at stock height.
I'm on 350Z revised springs which is only about a .5 drop and out of spec. I was also on Espelir springs which is only about a 1" drop and was way out of spec camber wise.
Old Dec 5, 2011 | 11:09 PM
AzuMaster's Avatar
Eibach Prokit is the way to go. Just remember the toe bolts if you don't wanna get the camber kits. 1.1F/1.0R as stated by their website. Or you can run some Tein S Techs 1.2F/0.9R. Good luck.
Old Dec 7, 2011 | 10:02 PM
g35915's Avatar
hey guys i just bought the eibach pro kit with eibach rear camber kit and new shocks and springs anything else i might need ??
Old Dec 7, 2011 | 10:34 PM
Jhambor's Avatar
The H-Techs are they way to go if trying to avoid a camber kit. They're the best overal spring as well as far as spring rate goes...closest to oem. The 350z version will give you slightly more drop than the G35 version. Any more of a drop and you will most likely need camber kits for both front and rear. The fronts of our cars do not come with manual camber adjustablity from factory, so a signifigant drop requires aftermarket kits for sure.
