I think my heater may be going out.
Old Dec 6, 2011 | 03:40 AM
tibasnatch's Avatar
Past couple says it seems to work fine....then blow colder...then blow warm again and back to colder...quite weird...any idea why?
Old Dec 6, 2011 | 03:56 AM
Songle6MT's Avatar
Thermostat, heater core, coolant temp sensor?
Old Dec 6, 2011 | 10:12 AM
Irrelevant's Avatar
Have you removed the cabin temperature sensor from the list of possible culprits by testing the system in manual mode to see if the problem still exists?
Might check your coolant levels as well. Low engine coolant, or air trapped in the system might be causing the problem.
Old Dec 6, 2011 | 11:34 AM
HYDRUS's Avatar
Have you changed your coolant recently? I did a few days ago and i have air trapped in the system which causes mine to do that. Just bleed the coolant system. Its free and easy so i would try that first. Hope this helps.
Old Dec 7, 2011 | 03:56 AM
tibasnatch's Avatar
Have not done anything with coolent. I will check it out tomorrow...how do u bleed the coolent system?
thanks
DEMoLITIoN
Interior
47
Oct 6, 2018 10:44 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
vQFamily
Sep 30, 2015 01:17 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
