Service Engine Soon light
On my '04 G35 coupe, I cleaned my K&N air filter and waited 24 hours for it to dry, and then reinserted it. While I was waiting for it to dry and it was getting dark I moved the car inside.
I was wondering if this is the cause of the Service Engine Soon light coming on now. It has been a few days since I did the work and I figured it would clear out on its own.
Any ideas?
Any ideas?
My guess is your MAF sensor wasn't hooked up and it threw the code. Perform the ECU reset, either through the pedal method of by disconnecting the battery for a while (and make sure to press the brake pedal a few times after the battery's disconnected) and you should be good to go.
Thanks for the help.
mjfenix
Jul 17, 2015 02:07 PM
