trouble starting car occasionally
Old Dec 18, 2011 | 02:58 PM
tcpombomb's Avatar
Occasionally, my G has been giving me trouble starting some on some days. I gotto turn the key and it won't start up at all, but the power is working fine.
This has been happening every 5th or so time I go to start it. I usually have luck when I return the key to the normal position and try again, though. BTW I have a '05 g35 coupe 6mt
What could be the cause of this. Does it sound like the starter is going bad to you guys?
Old Dec 18, 2011 | 03:14 PM
redpearl99's Avatar
do you hear the starter trying to turn over or do you hear nothing at all?
Old Dec 18, 2011 | 03:17 PM
tcpombomb's Avatar
I don't hear anything at all
Old Dec 18, 2011 | 03:35 PM
partyman66's Avatar
Clean your battery terminals and then reconnect the terminals nice and tight. If it still doesn't start, try taking a piece of wood, like a 2 foot length of 2x4 or a thick wooden dowel, and put it on the starter and rap the other end of it with a hammer. If the starter solenoid is stuck, this might free it up.... and you'll know that was the problem if it all of a sudden starts after you do this. If this fixes it, you need a new starter.
redpearl99's Avatar
ur battery is prob gone
Old Dec 18, 2011 | 03:36 PM
redpearl99's Avatar
do what he said first, don't wack it too hard with the hammer
Old Dec 18, 2011 | 04:49 PM
tcpombomb's Avatar
thanks guy, I give it a try. Also, I sometimes hear a grinding noise while it turns over
Old Dec 18, 2011 | 06:05 PM
partyman66's Avatar
Oh man... if it's grinding, you should pull your starter immediately and look at the teeth on the starter gear. If they're ground up, replace it ASAP. You don't want to be using a starter that has ground or missing teeth on it's drive gear, or you could end up having to replace your entire flywheel if it chips teeth off of the flywheel or grinds them down too much. A starter is a cheap fix, a flywheel is not.... mainly due to the time it takes to pull the tranny and clutch, which can equate to a hefty bill unless you do it yourself.
Old Dec 18, 2011 | 06:41 PM
redpearl99's Avatar
OP, does it sound like grinding or does it sound like the starter is struggling to turn over but just can't get there ?
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
