Need Help Anyone!!!
Just replaced my spark plugs... But now my engine light is on and its sputtering. I checked all the connections and everything looks ok... Do the plugs need to be spaced? right now IDK whats wrong with it. its driving me crazy... HELP ANYONE!!
New members join DRIVER and ask question about their G35s and don't offer any information about what year or mods they have. Post pic in your Garage and fill out the information about your coupes or sedans so we can give you point on answers. Recently member broke his front bumper asking if it could be fixed. Nothing in his garage and zero information...was it an aftermarket bumper or OE? We can only guess with the answers...
Gary
Gary
Pulled from "Way to many empty garages"... So like fellow G member asked; What type of plugs were used and have you had the CEL checked?? Did you disconnect and reconnect the battery?? Help us and We'll Help you... Believe me, I have read and researched before even asking questions... Someone else has probably been where you're at now.. so yea... Let us know and we'll help you out.
It would be nice to get some information like said above.
But seriously, go back and check to make sure you plugged the connections into the RIGHT coil.
It is very easy to mix the 2 nearest to the firewall on the drivers side of the car up.
I installed DBL Platinum auto lite plugs, yes I disconnected the battery. Also I double checked this morning to make sure I had all the right connectors in...
Sorry didnt know that the plugs would make a difference...
Just an FYI you should have went with an NGK plug.
I don't however think that the auto lite plugs would make the car sputter like that since they are double platinum.
Most plugs are pre-gapped
Get the code read and post them up here.
what I suspected, you're having some misfires
http://www.obd-codes.com/p0300
http://www.obd-codes.com/p0327
double check to see if you didn't plug a harness into the wrong coil pack
OP- Take your time and check again.
Damn bro. I wish I didn't have to work at nights.. I would've gladly gone over and helped a brother out!! I thought i'd help out.. If you hadn't already fixed the problem...
Firing order is 1-2-3-4-5-6. Cylinders if looking at front of engine: passenger side 1-3-5 front to rear. Drivers side front to rear 2-4-6. Hope you got it working bro!!
