Clutch noise or a nitch into 5th gear
Old Dec 28, 2011 | 07:41 AM
g35OnTrackz's Avatar
i have a 05 red g35...down shifting into 5th gear give a little nitch first, or 4th high ref going into 5th, with a quick shift gives that nitch again.....WHAT IS THAT ?
Old Dec 28, 2011 | 08:59 AM
dunut's Avatar
Do you feel a click or hear gring sound when going into 5th? I am not sure what a nitch is.
Old Dec 28, 2011 | 09:04 AM
Yeah a grind noise
Old Aug 11, 2015 | 06:53 PM
FoxTailWhipz's Avatar
Originally Posted by g35OnTrackz
Yeah a grind noise
I know this is like 4 years old, but the same thing happens to me if I shift fast. When shifting from 4th to 5rh fast kinda like straight across at an angle it will grind a little. Then sometimes when downshifting into 5th, it will also. If I shift from 4th then neutral then 5th a little slower, it is fine. Idk what is it but it doesn't seem too serious.
Old Aug 11, 2015 | 07:27 PM
partyman66's Avatar
Is your car also red?
When was the last time you changed your tranny fluid?
Old Aug 12, 2015 | 10:34 AM
No my car is black. I haven't changed it since I bought it (about a month a go). The guy I bought it from just changed all of the fluids recently.
Old Aug 12, 2015 | 10:55 AM
Texasscout's Avatar
1) Syncros may be going out
2) Clutch may be going out
3) you suck at manual shifting
Old Aug 12, 2015 | 02:54 PM
partyman66's Avatar
Maybe ask him what type of fluid he put in the tranny. Our trannies are finicky and work best with OEM Nissan MTF. I'd start by putting that in if not already and make sure it's filled to spec. You could even do a slight overfill by parking the side of the car with the filler hole on top of a slightly raised surface and adding a bit more fluid than it took to fill it while it was on flat ground.
Old Aug 12, 2015 | 02:57 PM
OK thanks! I'll see if that works.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
TheBay
Sep 3, 2015 03:27 PM
