Gas tank not filling
Old Jan 4, 2012 | 08:39 PM
steve21's Avatar
wtf? whats this line for?
I try to fill it and I get to half tank and it stops. My warrantee is over so are there any good shops in so cal that wont charge an arm and a leg to fix it?
Old Jan 4, 2012 | 11:20 PM
04G35NYC's Avatar
I had the same problem, the dealer just reset my ECU and did something with it. I didn't have warranty good thing i knew someone who worked there.
Old Jan 5, 2012 | 01:56 PM
thepro78's Avatar
How do you know it's only filling up to half tank?
are u going by what the needle tells u? Cause my Low gas light turns on after only 120miles but I have way more gas than half a tank...
Old Jan 5, 2012 | 02:43 PM
GR6RR's Avatar
there's a known problem with these g35s... search for gas gauge weirdness, you will soon find out what you need to do.
Old Jan 5, 2012 | 02:55 PM
HYDRUS's Avatar
If you leave the nozzle on low instead of delivering a higher volume its has been known ti help because it lets the fumes escape. Hope this helps! It did with mine
Old Jan 5, 2012 | 02:58 PM
thepro78's Avatar
yeah I have actually ran my g for 330Miles with the low gas light on since 130miles lol.. I will clean the Damn sending units sometime soon... lol
Old Jan 5, 2012 | 05:52 PM
Mark2K8's Avatar
Yea mine does that too and its so annoying. You have to hold the nozzle like 3/4 of the way in and it will continue to fill up normally. Sucks cause you can't use the nozzle holder and chill while it fuels
Old Jan 6, 2012 | 03:29 PM
spinna001's Avatar
When i go to the 7-11 by my house it happens to me as well. went to the BP down the road never happened again. Try a different gas station first could be a faulty pump.
Old Jan 6, 2012 | 04:24 PM
Gsouske35's Avatar
There is actually a TSB on this and it happened to my 07 G35. I was low on gas and when I went to fill it up it just stopped, in fact gas spilled back out. I had warranty still so I drove it to the stealership, I dont remember the details but they were saying they had to cut something inside the gas tank or something, they removed my rear seats and everything to get to it. I think if you were to take it in, you might have to pay around $500.
Old Jan 6, 2012 | 04:54 PM
NATH_19's Avatar
Do a search and there is a tutorial on how to fix this. No need to pay the stealership ...
Old Jan 6, 2012 | 10:27 PM
VQ35DE-G's Avatar
Power to the DIYers! Haha Glad to know that there is a way to fix this problem.... I'll be ready and expecting this. Thanks for the solution!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
Claudiu
Sep 26, 2015 01:04 PM
