Will 305s fit on a G?
Old Jan 9, 2012 | 07:46 PM
pvdg35's Avatar
Anyone running 305s on their G? Will they rub? I want to go as wide as possible w/o rubbing. Thanks for reading.
I'm currently running 275/35/19R GTS sitting on tein coilovers lowered to the max.
Old Jan 9, 2012 | 09:02 PM
herrschaft's Avatar
size of wheels? offset? rolled fenders?
Old Jan 9, 2012 | 10:44 PM
gary c's Avatar
Herrschaft's right, depends on all the above...^...! What is the purpose of running 305s anyway? Chances are if you're NA you may not be lighting up the 275s, why go larger?
Gary
Old Jan 9, 2012 | 10:59 PM
broke_as_ajoke's Avatar
i run a 285 in the rear. and it's kinda close.. I do have my fenders rolled and i run 20/30/285, 11 inch rim sit on Eibach Pro kit springs
Old Jan 9, 2012 | 11:17 PM
JaE35's Avatar
Moderator
G35 Sedan
G35man04 used to run 325's on his coupe
Old Jan 10, 2012 | 09:21 AM
jstudrawa's Avatar
Gary
It's mostly about the look. Granted, more rubber does have handling benefits and rain traction is always more = better, but I'd wager it's for looks.
Same reason people pay for spoilers and grills. Performance?
Old Jan 10, 2012 | 06:09 PM
DrewDrew's Avatar
OP stated he has GTS. Volk GTS I take it? Pretty sure that we all know the standard set up for them is 19x9.5/10.5 et +17/+18. You had to have your fenders rolled by now, if not, I'm shocked.
Several people have had 295s on them, I don't see why 10 mm would hurt anything. You might have to add some camber from your current specs so they don't rub, but they will certainly fit considering others have run wider set ups on stock body/fender work, ie. g35man04.
Old Jan 10, 2012 | 07:51 PM
TruGame's Avatar
I'm running 295/35/20 10.5 rim and it's close but my fenders are not rolled and I'm on stock springs, you will need more -camber
Old Jan 10, 2012 | 08:00 PM
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by g35man04
you need to put some spacers on the rear!! Pull those rear wheels out!!
no spacers on rear with a 325/30/20 tire installed!
xxr 521's i believe
Old Jan 10, 2012 | 08:47 PM
pvdg35's Avatar
offsets are +17 and rims are 10.5 for the rears (I was referring to Volks GTS when I had put GTS) Fenders are rolled, i still have a bit of neg camber with the camber kit but not as bad as it was before. I had 275 before and just want to try a bigger size for better traction. here's a pic of my ride. I know the gas tank lid is not flush,..long story...involves two girls.
Attached Thumbnails Will 305s fit on a G?-316463_292359130776887_100000084069875_1294205_591942944_n.jpg
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
