View Poll Results: Wheel Size G35 coupe
19x8.5 F 19x9.5 R
13.33%
19x9 F 19x10 R
13
86.67%
Voters: 15. You may not vote on this poll
Opinions on wheel sizes
Old Jan 28, 2012 | 06:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
245 on a 9.5" rim is barely stretching.
Old Jan 28, 2012 | 06:19 AM
davidblak3's Avatar
Originally Posted by gary c
David these offsets....^.... are wrong! Guaranteed if you use 40 offsets in front your wheels will rub inside on tight turns causing you to lose control....I should know happened to me! Buy wheels 19X9.5 (f) and 19X10.5 (r) with low to mid 20s offsets, you won't need spacers and they'll fit perfectly. Tire sizes can be 245/35s (f) and 285/35s (r).
Gary
They only offer the front with that specific offset, would it be better for me to get the 19x9.0 with a +32 in the front or just go 19x10.5 in the front I don't completely understand offsets even after reading the tire rack article about offsets I just want my wheels to look nice, they don't have to be flush but they can be close to flush, and also keep the handling of the car because I drive my car like a sports car
Old Jan 28, 2012 | 10:10 AM
gary c's Avatar
If that's the only offset they offer with these wheels you need to find another brand that looks the same and will work for your G. My first set of Volks had 40 offsets in front, when going thru a tight turn the wheel would hit my suspension and jerk the steering wheel out of my hands....not a good experience and a major wake up call!
Gary
Old Jan 28, 2012 | 05:54 PM
davidblak3's Avatar
Gary
It looks like the guys over at my350z are running these exact wheels with 19x8.5 in the front and 19x10.5 in the back the front offset is +20 not sure if this would work or even in the 350z has similar offsets to the z
Old Jan 28, 2012 | 09:05 PM
05g35dy's Avatar
if there +20 then thats good
Old Jan 28, 2012 | 11:13 PM
gary c's Avatar
David you posted the 19x9 had a 41 offset and that's all they had available, if you can get the 20 that would work....Gary
Old Jan 29, 2012 | 12:24 AM
davidblak3's Avatar
Yeah I did original think those were the only sizes availible but I found the 19x8.5 size for the front. So just confirm neither the 19x9 or 19x9.5 will fit with the offsets that I listed. Only the 19x8.5
Old Jan 29, 2012 | 01:04 AM
flyz's Avatar
You could always get 15mm spacers for the front if you're set on these wheels. Not ideal as to getting proper offset rims but at least it'll work.
This will give you 9.5 +26 and 10.5 +27,
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
