HELP! Failed Smog
Old Feb 9, 2012 | 01:27 AM
gary c's Avatar
Originally Posted by lil beezy
Is that the driver or passenger side?
HAHAHA....yea right side or passenger/shotgun side, beezy.
Gary
Old Feb 9, 2012 | 08:06 AM
Jee_35's Avatar
I had that code as well, got a tune and that took care of it.
Old Feb 9, 2012 | 12:44 PM
lil beezy's Avatar
Gary
I wasn't sure which way you were going under the car! Hahahahhaha
Old Feb 9, 2012 | 03:32 PM
snowrider13's Avatar
I failed smog the other day for some reason that I cannot figure out. I had an SES for the code P1273 while I had on the MD ART Pipes. I took off the pipes and reset the ECU and the code hasn't come back. The car may have been cold, since I had to leave it at the smog shop while another person got smoged first. I have an MREV2, 5/16 plenum spacer, and a Z Tube. My exhaust is completely stock now. I have driven about 300+ miles since taking off the test pipes and haven't gotten and SES light back. What could be going on!? Any help is appreciated! I attached the smog report from the failure.
Give them some$$$$
Old Feb 9, 2012 | 10:32 PM
strykez's Avatar
your not failing by much.. just beat the car a bit it'll bring your hcs down by burning off carbon. you can also do a tune up if you havent done one in a while and i wouldnt change your sensor unless you get a code for the sensor or if you hook a scan tool up to it and see its not responding, or its reading incorrectly. whats the mileage on your car? if your close to an oil change do that as well.
Old Feb 10, 2012 | 03:18 AM
Majiks's Avatar
also why does it say the test if for a single exhaust ?
Old Feb 14, 2012 | 12:52 AM
lil beezy's Avatar
76,500 but the engine was replaced at 39,000 due to the oil consumption issue. i am pretty close to an oil change so i will do that and hook it up to a scan tool.
Old Feb 14, 2012 | 12:53 AM
lil beezy's Avatar
hmm, good point. i don't know.
Old Mar 14, 2012 | 02:12 PM
lil beezy's Avatar
just an update guys, i got it to pass, just barely... turns out it was because my cats are a bit dented from being so low. he told me i will probably have to get new cats for my next smog. i am just gonna put my art pipes back in and have the cats sit until the next smog. thanks for all the suggestions guys.
Old Mar 14, 2012 | 03:52 PM
That's G's Avatar
For future smogs, just take it to some ghetto shop where every car passes. I've seen p.o.s. cars blowing plumes of smoke during a smog in some Santa Ana shops and thing still passes. All the shop wants is its $$$.
Old Mar 15, 2012 | 02:42 AM
Gisele's Avatar
Originally Posted by Mark2K8
Thank God we don't have this smog bullshit here in florida...
what a pain in the *** and a hassle
Yea agree. Live in tampa fl all my life never heard of these kind of testing. Very inconvenient
Old Mar 15, 2012 | 05:28 AM
threatcon07's Avatar
Go to Corner 3 Garage in Lake Forest, the mechanic Steve was a Nissan Master Tech and knows our cars inside out. I wouldn't go to Carzone, had a horrible experience there.
Very true! I'm in Orange County which is quite a ways away from those shops. I really appreciate the help though! I'll just have to find a place around here that makes more sense.
Old Mar 31, 2012 | 02:33 AM
Cabos G35 Coupe's Avatar
Bank 2 sensor 1? You guys know
Old Apr 5, 2012 | 11:40 AM
KNINEMUZIC's Avatar
Question... My check engine light is on. I know there's a way to pass smog ( i did it before but forgot the exact steps) i know i need to disconnect the battery, reconnect it and then drive between a certain mph and for a certain amount of time... Anyone know the details regarding this???
Old Apr 8, 2012 | 04:32 PM
  #30
lil beezy's Avatar
reset your ECU.
