HELP! Failed Smog
Old Feb 7, 2012 | 02:29 AM
lil beezy's Avatar
HELP! Failed Smog
I failed smog the other day for some reason that I cannot figure out. I had an SES for the code P1273 while I had on the MD ART Pipes. I took off the pipes and reset the ECU and the code hasn't come back. The car may have been cold, since I had to leave it at the smog shop while another person got smoged first. I have an MREV2, 5/16 plenum spacer, and a Z Tube. My exhaust is completely stock now. I have driven about 300+ miles since taking off the test pipes and haven't gotten and SES light back. What could be going on!? Any help is appreciated! I attached the smog report from the failure.
Old Feb 7, 2012 | 09:53 AM
gary c's Avatar
None of your mods should have caused you to fail your smog inspection. If you live in SoCal I can send you to a couple place that can figure out why you failed....Gary
Old Feb 7, 2012 | 12:53 PM
lil beezy's Avatar
Yes I am in SoCal, but I don't have a bunch of money to spend.
Old Feb 7, 2012 | 01:16 PM
Massios's Avatar
1273 is a lean code on bank 1. The car being cold combined with your MREV and spacer may have caused this.
Old Feb 7, 2012 | 01:17 PM
gary c's Avatar
Not passing smog you don't have a choice but to spend enough to get your G to pass....right? Smog stations only give you one crack at getting it fixed before they charge you for another test. The two shops I would recommend are CARZONE in the valley 818-373-1330 or Magic Auto Center (Chris) in Valencia 661-291-1232. Which ever is closer to you, they don't charge what the stealerships do....Gary
Old Feb 7, 2012 | 01:19 PM
bluedevils95's Avatar
Really? That hard to believe
Old Feb 7, 2012 | 07:23 PM
lil beezy's Avatar
Tony from MD told me that bank one is in the header... Would I maybe just need to replace that O2 sensor?
Old Feb 7, 2012 | 07:25 PM
lil beezy's Avatar
Very true! I'm in Orange County which is quite a ways away from those shops. I really appreciate the help though! I'll just have to find a place around here that makes more sense.
Old Feb 8, 2012 | 02:42 AM
TemjinX2's Avatar
you can always add a little bit of alcohol to lower your HC count. but all you really need to do is basically beat the car on the freeway and get your cat nice and hot and when you go to the smog shop, leave your car on until you take the test. Also make sure your using 91 oct gas.
It harder to pass lower speed smog since it takes awhile for the cat to heat up.
Old Feb 8, 2012 | 03:39 AM
lil beezy's Avatar
yeah, i'm gonna drive the car to school and back tomorrow then straight to the smog check place. leave it on and hot until the test. if i haven't gotten an SES light since i took off the pipes, do you think it just could have been a leak in the headers to test pipes section? my sensor is most likely still good, correct?
Old Feb 8, 2012 | 09:39 AM
gary c's Avatar
When you throw the CES error code and clear it the first couple times it takes a while for it to come back but eventually you can't get out the driveway without seeing it. I had to replace the right bank sensor when I installed my Berk's, you may need to also. If it's bad it won't go away and you won't pass smog....Gary
Old Feb 8, 2012 | 12:32 PM
lil beezy's Avatar
ok, thank you. but it has been off for a couple weeks now, about 400 miles. so it should be ok then right?
also, is that code for the left or right sensor?
Old Feb 8, 2012 | 02:37 PM
gary c's Avatar
I believe bank 1 is the first sensor on the right side (when under your car) that's what I replaced too....Gary
Old Feb 8, 2012 | 10:48 PM
lil beezy's Avatar
Is that the driver or passenger side?
Old Feb 9, 2012 | 01:06 AM
Mark2K8's Avatar
Thank God we don't have this smog bullshit here in florida...
what a pain in the *** and a hassle
