19 inch rims (HELP)
Old Jan 2, 2005 | 09:26 PM
Derek S's Avatar
19 inch rims (HELP)
Hay guy hows it going. this is derek i got a quick question for you guys. i want to get some new rims, 19s and i was looking at the PIAA Supper Rozza. my question is if i put the 19s on my 04 coupe with performance wheels and tire upgrade will the car look lifted or will the hight be the same as the 18s i have right now under it. i dont want to drop the car i dont want to loose the warranty.
Old Jan 2, 2005 | 10:11 PM
neffster's Avatar
Hey,
Go here tire size calculator. Enter the stock tire size then enter 275/35/19 for the rear on the PIAA's and do the same with a 255/35/19 for the fronts (make sure to update the front stock tires to the correct size). May I also suggest price checking with pimpinpearl (Josh). He got me the best deal possible on my PIAA's. Make sure to tell him that Neffster sent you and you want a good deal like I got.
Good Luck.
Old Jan 3, 2005 | 12:24 AM
Finiti35's Avatar
FGC South Florida BOD
What Neff said. I just played around with the tire size calulator and it shows that the height up front will be absolutely the same as stock (26.0") and the rears will be 26.6" vs 26.7" stock diameter. So the 0.1" difference will be minimal, even the difference in the treadwear between stock and aftermarket tires will be more significant IMO.
You're not going to void your warranty if you lower the car btw.
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
