Scratched My G35 This Morning...Need Advice...(Pic Included)
Old Feb 16, 2012 | 07:59 PM
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by snowtrax
It would cost probably $225 for a body shop around here to do that
Old Feb 16, 2012 | 08:05 PM
jwolfpk's Avatar
whatever your gonna do either touch up or body shop i would do it quick cuz it looks like it went down to the metal and will probably start to rust if it sits long enough
Old Feb 16, 2012 | 08:52 PM
1SlowSedan's Avatar
Well, if you want to go the on the "budget" route, take high grit sand paper to it to smooth out the surface. Light primer and oem paint, and make sure to blend the paint to the outside. I wouldn't suggest you do it but if you're on a tight budget go for it. Can't grantee it'll look perfect though.
Old Feb 17, 2012 | 01:45 AM
FreshFromATL's Avatar
Thanks for the info fellas...I will keep y'all updated. I am going to try to get the oem paint from a local infiniti dealership and do everything tomorrow afternoon. I will post pics when I'm done.
Old Feb 17, 2012 | 04:35 PM
UPDATE......
Here are the pics...I went to my local Infiniti dealer and they supplied me with the original oem paint which matched my car perfectly...now I just have to sand it down to smooth it...I'm impressed tho...I will post more pics once I get a chance to sand it down and blend it...
Old Feb 17, 2012 | 04:37 PM
ALSO...That particular paint works well if you have minor scratches on your factory rims...
Old Feb 17, 2012 | 06:48 PM
1SlowSedan's Avatar
Off to a good start, keep us posted.
Old Feb 18, 2012 | 08:52 PM
VQ35DE-G's Avatar
Looks good compared to where you started.
Old Feb 19, 2012 | 02:42 AM
madmaxx72's Avatar
A buffer ain't going to do much... You need to smooth it out with some sand paper... I would start with 1000 grit and work your way to 1500 or 2000 grit this is with water , you took some paint of so after you smooth everything out fill the spots with no paint with the touch up and let dry real good after that you take some 2000 grit sandpaper and water to blend in the touch up and then you buff it to a shine and it will hide pretty good... You will need to get real close to see it
Old Feb 19, 2012 | 02:47 AM
madmaxx72's Avatar
Never mind... Didn't see the 2nd page but you should hade it sanded before the touch up paint was applied then sanded again to blend and last a buff.
Old Feb 19, 2012 | 10:49 PM
STLG35guy's Avatar
Better fix that G man. That don't look pretty
Old Feb 19, 2012 | 10:50 PM
STLG35guy's Avatar
If its starched down to the metal you can only make it look so good ya know
Old Feb 19, 2012 | 10:51 PM
STLG35guy's Avatar
Edit scratched iPhone won't let me do a normal edit :-/ don't mean to over post
Sepsis
Feb 12, 2020 02:05 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
