Transmission Question(5AT)
Old Feb 17, 2012 | 05:20 PM
TheBigG's Avatar
Hey guys, not sure if I have a problem or not but just wanted to see how many people experience this or if its considered "normal". I found some answers through search but it was mainly for the newer sedans. People described it as "engine braking"...but I've never experienced that in an auto before. Details, 03, 96k, no mods.
So when driving the car shifts pretty good, pretty normal for a 96k car. The thing that slightly concerns me is when I'm not on the gas pedal the car feels like its hanging in the current gear and its slowing down(almost as if I was driving a manual and slowing down leaving it in gear, like engine braking), it will eventually go low enough on the rpm's and downshift to the next gear all the way to 1st. I've never owned an automatic that did this, everything I've driven when you aren't on the gas it goes into a neutral feel.
Normal? issue?
Thanks guys
Old Feb 17, 2012 | 05:31 PM
Blue Dream's Avatar
I drove ttrank's car solo
It's called rev matching and it's perfectly normal for our cars. I think it benefits the 6MT more than the auto, but that's just my opinion.
Old Feb 20, 2012 | 01:35 AM
TheBigG's Avatar
It's extremely annoying....I like being able to let off the gas and coast and not feel like the car is being restricted. Why would they do this?
Old Feb 20, 2012 | 01:37 AM
MADtotheA's Avatar
This doesn't happen in my car.
Old Feb 20, 2012 | 01:52 AM
Revo's Avatar
This isn't rev matching at all dude...
OP, I take it you are in D and not in manual mode?
I'm not totally familiar with the Nissan/Infiniti automatic transmissions, but most automatic transmissions will naturally upshift to the highest gear possible when you let off the gas, as well as unlocking the torque converter, which gives the perception of "coasting" since a torque converter translates very little back-torque (torque from trans to engine). Sounds like your transmission is not doing this.
I would start off by checking your transmission fluid level. Maybe this is just older automatic transmissions, but I've heard of low AT fluid causing all kinds of weird stuff...
Old Feb 20, 2012 | 02:01 AM
TheBigG's Avatar
Yes I'm in D mode. I have to bring it in for scheduled maintenace anywho and the tranny will get a fluid change. Hopefully its nothing major!
Old Feb 20, 2012 | 09:06 AM
gary c's Avatar
My guess is once you've had your trans serviced what you're experiencing will go away. Fluid might be low or contaminated, there's no filter so a simple drain/fill should make your trans/and you happy.
Gary
Old Feb 20, 2012 | 09:10 AM
STLG35guy's Avatar
Goodluck
Old Feb 20, 2012 | 10:28 AM
snowtrax's Avatar
Both my '05 with 99k and my '08 with 10k do this so I think it's just a characteristic of these cars. The people who say theirs don't do it probably are used to it and don't notice it. Coming from the BMW world, I noticed this immediately however, I don't think there's anything wrong with it. You should still change the transmission fluid for other reasons though.
Old Feb 20, 2012 | 11:43 AM
BlkCoupe's Avatar
2003 AT coupes do not have rev matching. I wish they did!
Old Feb 20, 2012 | 12:19 PM
rhampsterwha2's Avatar
my 07 5at does this too, tranny was serviced recently when my new short block was installed and i remember it doing it back with the OC engine + unserviced tranny
if im in manual mode and select 5th gear it does not do this but with in D mode and go same speed then let off it feel like engine breaking slowing me down.... i drive in manual 95% of the time anyway if that makes a difference
Old Feb 20, 2012 | 01:02 PM
freakta's Avatar
Ya these cars do that. It's not drastic but they do it. It's just normal
Old Feb 20, 2012 | 02:06 PM
i figured it was just thought id post up saying i had noticed it on both instances
if you wana coast slap it over to manual then select the highest gear you can
Old Feb 20, 2012 | 04:06 PM
joedaddy1's Avatar
isn't this normal for automatics? i think it's more "apparent" in the G35 since it revs a bit higher than an average car due to gearing..
for example.. say you are in the 3rd gear.. 50mph.. your engine "resistance" will slow down your than say being on 5th gear 50mph.. just more work/resistance on ur transmission at a higher RPM...
CVT and Hybrids seems to be exact opposite.. there's almost zero resistance.. kinda like being on neutral.. save a lot of gas...
Old Feb 20, 2012 | 04:10 PM
agree around town you dont see it but on the high way (55mph+) even in 5th it pulls you down
