Passenger Reverse Light Out
Old Feb 21, 2012 | 09:39 PM
jsm11482's Avatar
Question Passenger Reverse Light Out
Hi, someone pointed out to me that my passenger side reverse light is out. I have an '03 G35 (2nd release; without the trunk handle on the outside).
Here's where I'm at:
  • I replaced the bulbs on both sides but the passenger side is still out.
  • I tried the "harness" and bulb from the passenger side with the driver side wiring and it worked fine.
  • It seems that no power is getting to the passenger side harness.
  • I checked the fuses in the interior driver side fuse bank and all look okay.
  • I checked the fuses in the fuse block in front of the battery - all okay.
  • I checked the fuses in the fuse block behind the battery - all okay.
  • I wiggled the harness and wiring including where the wiring leaves the trunk hood and enters the body of the car - no effect.
What else should I look at or do? Thanks.
Old Feb 21, 2012 | 10:03 PM
g35sleeper123's Avatar
Mine does the same thing, but its randomly. Sometimes it works, sometimes it doesnt. I have checked all the connections, its really annoying
Old Mar 4, 2012 | 09:14 PM
si_driver's Avatar
Both of my reverse lights are out. (Never mind, only the passenger light is out) Also my trunk light is out too. Bulbs seem to be fine.
Not sure if this is related but for a while my SLIP and VDC off, ABS lights would turn on sometimes, after restarting the car they would always go away.
Now for about 1 month these light stay on the whole time. The car doesn't still work just fine, but it appears that the ABS system isn't working at all.
Muski_G
Dec 1, 2023 11:11 AM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
