Rear Camber vs Front Camber
Old Feb 24, 2012 | 05:49 PM
916TownG35's Avatar
Would it look weird if I had less camber in the rear than the front? The front camber kit is pretty expensive, so I'm planning to pick up the rear spc camber kit for now. The camber is sitting at around -3.3 all around. I'll probably set the rears to about -1.0.
Old Feb 24, 2012 | 05:50 PM
Shanes_G's Avatar
you should be fine with just the rear camber kit.
Old Feb 24, 2012 | 06:08 PM
DrewDrew's Avatar
It'll be noticeable. It'll look funny to people who aren't used to lowered/stanced cars.
Just make sure your front toe is set as close as possible to 0, and flip the tires every 5-6k.
Old Feb 24, 2012 | 06:22 PM
916TownG35's Avatar
I'm really tucked also, I'm sitting on stock 18s, so I feel that it won't be as noticeable. What do you think?
Old Feb 24, 2012 | 06:26 PM
NorthDakota's Avatar
Ichiba front camber kit. $309. not too bad. and if you plan on having your car through an entire set of tires it might save you money. If not then don't worry about it. http://www.conceptzperformance.com/C...3697.92.11.113
Old Feb 24, 2012 | 06:49 PM
CandlestickPark's Avatar
ill Sedan
I would stay away from Ichiba suspension parts (front and rear camber kits). They have failed on several cars on here
https://g35driver.com/forums/brakes-...l-garbage.html
https://g35driver.com/forums/brakes-...killed-me.html
Old Feb 24, 2012 | 07:09 PM
DrewDrew's Avatar
Ichiba kits are also known to not get into spec after an aggressive drop - mainly for adding negative camber. Stick to SPC and SPL for front camber kits.
If you're gonna be rolling with stock 18s, at least invest in some 25-30mm spacers to make it look not-so-goofy.
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
