Clutch oriented.
Clutch oriented.
I'm pretty sure my clutch issues have been dealt with before, but I really need assistance before I proceed.
Engaged my clutch and it went down easy enough but stayed down. I pulled it up and tried again but the same thing happened.
I cannot shift my gears and the car is stuck in neutral.
I am fairly certain that either my slave or master cylinder has gone out. What I wanna know is this:
Is this my best bet as far as fixing my issue? If I buy a new Slave/master cylinder would I be wasting my money or will it fix my problem?
You could try bleeding the clutch fluid before buying parts. This will sometimes happen with old clutch fluid when the fluid gets hot, but it will usually go away once the fluid cools. Air in the system could also cause this problem. If bleeding doesn't work, then yes, you will need a new slave or master cylinder.
I bled out all of the bad fluid.
A new Slave and Master are on the way. No big deal. More likely, if I succeed, my clutch will shift better because of the newer parts and I plan to replace with Dot-4.
jbmw002
Sep 10, 2015 12:54 AM
