03 coupe transmission sounds
Mar 12, 2012 | 11:09 AM
I am looking to buy this 03 coupe 6mt with 95 miles on it. When I test drove there are some strange sounds coming from the transmission. The gear stick also vibrates a lot in the lower gears.
The sound is like tuk-tuk-tuk. The seller saying that’s because of the new fly wheel he installed.
Anyone seen this issue? I read some forums about grinding transmissions but not sure if this is the same issue.
I would appreciate if you have any advice/suggestions.
Thank you.
Reply 0
Mar 12, 2012 | 11:35 AM
How does it shift ? Any difficulty getting into and out of gear ? Notice any slippage ? Aftermarket clutch and flywheels are known for being loud and making a chatter sound .
Reply 0
Mar 12, 2012 | 11:39 AM
Quote: How does it shift ? Any difficulty getting into and out of gear ? Notice any slippage ? Aftermarket clutch and flywheels are known for being loud and making a chatter sound .
Yes it shifts ok. I did not notice any slippage.
Did not hear any noise in fifth and sixth gears.
Reply 0
Mar 12, 2012 | 11:55 AM
Could it also be axle click?
Reply 0
Mar 12, 2012 | 02:45 PM
Vibration and noise coming from the trans when it shifts correctly indicates a worn out throw out bearing. Eventually if not replaced won't allow you to get in gear....Gary
Reply 0
