Coupe Not Starting
Old Mar 14, 2012 | 03:18 PM
islandtuner242's Avatar
Coupe Not Starting
ok recently when i tried to start my car it rolls over and takes a while to start so i chalked it up to the fact that it may need to tune up/ fuel pump issue............. but just a few days ago i went out for a drive (20 mins.) parked the car and when i was leaving it did the usual but then it died as soon as the key turned to start the car......... tried 2 batteries and the last one i tried was draining the car that was giving me a jump and now i'm stuck with a car that won't start as if all of the batteries are drained
any advice would be greatly appreciated thanks in advance
Old Mar 14, 2012 | 04:11 PM
lostangels01's Avatar
Are you getting a check engine light? Other members would say its the starter. Get it checked out it first to rule it out. I say you might need to replace the camshaft sensors. Get or borrow a OBD-scanner and check for engine codes.
Old Mar 14, 2012 | 04:23 PM
ohsixmtee's Avatar
Were both batteries you tried tested good? It honestly sounds like you're dealing with low CCA's.
Old Mar 14, 2012 | 07:19 PM
superchargedg's Avatar
From the brief description sounds like a bad alternator to me.
Old Mar 17, 2012 | 09:33 PM
@ lostangels01 i recently changed the crank angle sensor and i'm planning to change the camshaft sensors this week hopefully but i used a scan tool yesterday and nothing came up so the starter is what i'm guessing is the culprit right now.... and from previous car problems once the starter goes the alternator is next in line so i'm changing out the alternator as well
Old May 12, 2012 | 03:41 PM
Here is a link to the video I posted I hope this helps in understanding the situation better
Old May 12, 2012 | 06:13 PM
live fast's Avatar
i think its your crankshaft sensor
Old May 12, 2012 | 06:19 PM
I've already changed all of the cam and crank sensors
Old May 12, 2012 | 06:58 PM
chinamansteve's Avatar
New G owner here, had the G for ~two weeks and this morning i had this same problem for the first time, but the car is now back to normal when i start it.... I hope it's not too big of an issue!
Old May 12, 2012 | 11:44 PM
strykez's Avatar
had a g in the shop with the same problem it ended up being the camshaft sensor. if you take them out you can check the resistance and see if they're still good cant remember the spec though you'd have to look it up. as for changing the starter then the alternator going right after that makes no sense at all so don't change the alternator unless the diode ripples are messed up or its not charging properly. The starter has nothing to do with the alternator the starter just starts the car then its job is done the alternator keeps the battery charging when the car is running if your battery is weak it can cause the alternator to go because its so low on charge the alternator has to work extra hard and the alternator going bad can cause your battery to go because its never getting charged hope this helps
Old May 12, 2012 | 11:47 PM
strykez's Avatar
oh and the video you showed its 100% not the starter because the starter is doing its job its turning the engine over
Old May 13, 2012 | 12:09 AM
supreme1911's Avatar
yeah definitely not ur starter. But if you ur starter keeps going thru those starts ups its not gonna last
Old May 13, 2012 | 01:14 AM
sugars's Avatar
It might be ur fuel pump...my friend that a problem like that and it turn out to be a bad fuel pump..
Old May 13, 2012 | 07:40 AM
onthe3rdday's Avatar
Scan tool it again and find out why the engine light is on.
Old May 13, 2012 | 09:34 AM
HotRodG35's Avatar
Definately not your starter.
I agree with "SUGARS" the fuel pump is probably going bad.
For the people who don't understand the link between battery, alternator and starter here it is.
When the alternator starts getting weaker it causes battery voltage to drop. When battery voltage drops requires higher amps for starter, which causes starter to wear out. When Battery not getting adequate charge and higher AMP draw it will lead to premature battery life.
