Loose Bolt~~Help
Old Mar 20, 2012 | 08:20 AM
jsmoon202's Avatar
Loose Bolt~~Help
Hey,
I just recently purchased a used 2003 Infiniti g35 coupe and have literally searched everywhere for a solution to my problem~~can't seem to find any kind of information on it. There is a loose bolt on my ac compressor~~and no matter how much I tighten it, it seems like the clutch plate it is holding keeps turning with the bolt not letting me screw the bolt in at all~~I found a maual where it states I need a clutch disc wrench~~which I don't have. I called Infiniti and they want 135 dollars just to diagnose the problem even if it is a simple bolt tighten~~that is just too much. I have some pics attached to show you the bolt.~~The ac is working fine but due to the loose bolt it is squealing like crazy~~
Any ideas on how to tighten this bolt without the special tool? Please reply asap. Thank you.
Old Mar 20, 2012 | 08:46 AM
jstudrawa's Avatar
I don't know jack **** about the issue, but I do know that you can rent specialty tools from autozone or advance.
Now sure if they have what you need, but worth checking.
Old Mar 20, 2012 | 10:08 AM
DKano's Avatar
or take it to a mechanic and ask them to tighten it, doubt they'd charge you $130 to tighten a bolt! That bolt looks a little rusty too, so why not get a new one while you're at it too.
Old Mar 20, 2012 | 12:45 PM
LoSt180's Avatar
According to FSM, the A/C compressor uses a magnetic clutch. You should be able to unplug the harness and apply battery power directly to lock the clutch. It might allow you to tighten the bolt.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
prinny
Nov 22, 2015 11:07 PM
6spdGspot
Oct 5, 2015 01:55 PM
doakley92
Sep 25, 2015 12:58 PM
