Universal Radiator Fan wiring issue
Old Mar 24, 2012 | 09:08 PM
deasons22's Avatar
I just bought a Aluminum radiator with a fan shroud and the fans only have a power and ground connection. I checked both of the connectors for the fan and they have a red and black cable, but also a two other wires. I wondering if i can cut the connector off and wire up the fans like that or if i should do something else.
Also if anyone knows a way to setup a 350z radiator, with the mount points on the top I would appreciate it.
Thanks, Sam
Old Mar 24, 2012 | 09:20 PM
CandlestickPark's Avatar
ill Sedan
Not sure if this will help you, but this is how my forged racing fans are hooked up.
https://g35driver.com/forums/engine-...an-shroud.html
Old Mar 24, 2012 | 09:36 PM
deasons22's Avatar
Sweet, yea that will work for one of them. On the connector that is longer i have red instead of green for that one. If i hold the connectors the same way, red and green are in the same position. Are those both the same?
thanks for the quick response
Old Mar 25, 2012 | 05:08 PM
deasons22's Avatar
Just wired it up and the fans appear to be working. Red and Green are the same for the record. I took some pics of the work if anyone is interested.
KevinnnVo
Oct 14, 2024 04:33 PM
Danielek
Aug 11, 2015 09:33 AM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
