Brake Dust
Old Jan 8, 2005 | 01:48 PM
xthecat's Avatar
Brake Dust
Has anyone tryed any aftermarket remedies to stop the brake dust from collecting on the mags. Something other than harder pads or cleaning solutions, surely there must be some type of cover plate that goes over the brake system that prevents this?
Old Jan 8, 2005 | 02:15 PM
Z2G's Avatar
Z2G
oh man....this is a really old topic that hasn't been mentioned for about a year now, i think: ) but yes, you can purchase ceramic brake pads which you can purchase everywhere. if you have a 5at, i would wait till after the 3 yrs/36k miles mark since it is under warranty and you will get free brakes and rotors replacements. if you get aftermarket pads, it will void the warranty. just live with the brake dust until then.
Old Jan 8, 2005 | 02:50 PM
Ianbiz's Avatar
If you got aftermarket pads, and had the dealer install them, would it still void the warrenty?
Old Jan 8, 2005 | 03:36 PM
Z2G's Avatar
Z2G
i think it depends on the dealer. but, i highly doubt that it'll be okay. first off, under the warranty, parts and labor is covered for 5at brake pads and rotors. i don't think they will replace worn pads for aftermarket pads ( which you would supply ) while doing the warranty work. secondly, that would void the warranty for both pads and rotors. but, just call them and ask.
Old Jan 8, 2005 | 07:35 PM
xthecat's Avatar
I'am aware of harder pads ect, but I know that you can get a protective disc that covers the brakes and stuff. Right now they are only available for 15 & 16 wheels and recomended for Ford and GM, the question is 'does anyone make them for a G'.
Old Jan 8, 2005 | 08:01 PM
Shadow1's Avatar
I think someone has posted about these protective covers before also. Most people, including myself, thought it would make it look wierd. The wheels are open to be able to see the brakes, not a strange and probably very dirty piece of plastic. Even if the cover only went over the physical brake caliper I think dust would still get out unless it touched up against the rotor.
Unfortunately, it seems like all you can do is clean them often.
Old Jan 9, 2005 | 01:16 AM
RussB's Avatar
n00b here, but why are brake pads are covered under the warranty? every other car i've owned they're considered a wear item like tires.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
