Oil Leak Mystery
Old May 4, 2012 | 07:59 PM
grovefromnh's Avatar
As a suggestion: If you decide to remove the pan and replace the gasket, get the 1" pan spacer from one of this site's vendors. It will give you extra oil capacity. More oil is always better.
Old May 5, 2012 | 03:27 AM
dickjack13's Avatar
no
Do not pay $200 for the oil pan replacement its really little and takes about 15minutes from start to finish and i used a real gasket from autozone i dont trust the rtv by itself 8 months and no leak
Old May 5, 2012 | 10:36 AM
gary c's Avatar
There's no need to have the stealership do the job of resealing your oil pan. Check with Nissan or any qualified shop, shouldn't cost more than an hours labor + parts....Gary
Old May 7, 2012 | 01:39 AM
trulegend's Avatar
Is this the one you ordered?
http://www.autozone.com/autozone/par...323948_0_5285_
How hard is it to remove old rtv gasket?
I would assume drain oil unscrew and remove all bolts clean pan with blade and install new gasket.
Do I put any silicone anywhere?
Old May 7, 2012 | 01:50 AM
dickjack13's Avatar
ttt
yup thats the one and yeah scrape with a razor and usually u only put silicon (with gasket) on like corners but this oil pan has all round edges but i went ahead and put a small bead all the way around anyway plus gasket also get a new washer for ur drain plug. worked like a charm for me and since u allready did the oil cooler o ring u should be good to go and put new oil dont be cheap and try to reuse ha ha
Old May 7, 2012 | 11:04 AM
trulegend's Avatar
what silcone and where exactly did you put it? between the gasket? or around the edges? did you apply any near the bolt?
Old May 7, 2012 | 12:10 PM
dickjack13's Avatar
ttt
on the pan make a barrier inbetween the holes and the inside of the pan only a small bead
Old May 7, 2012 | 12:31 PM
trulegend's Avatar
what silicone? any high temp silicone? i am looking for either clear or gray, i have some at home which is orange and dont want to use
Old May 7, 2012 | 01:05 PM
trulegend's Avatar
also, what are the torque specs for the bolts? i don't want to over tighten them. Also i heard you have to tight them evenly when putting new gasket. is that true?
Old May 7, 2012 | 01:08 PM
dickjack13's Avatar
yeah any high temp rtv silicon i used orange
Old May 7, 2012 | 01:59 PM
trulegend's Avatar
anyone know torque specs?
Old May 7, 2012 | 02:06 PM
dickjack13's Avatar
just hand tight with rachet dont put any muscle into it at all but u might wanna look up the order start in the middle work ur way out
Old May 8, 2012 | 02:07 AM
trulegend's Avatar
A buddy of mine suggested I drop this in since it's a very minor leak.
http://barsproducts.com/catalog/view...stop-leak-e10l
Thoughts???
Old May 8, 2012 | 10:07 AM
herrschaft's Avatar
Thoughts???
Seems like a temporary solution if it actually works. Better off just fixing the issue.
Old May 8, 2012 | 10:10 AM
  #30
Illuminati's Avatar
I would rather pass on stop leak
