Help me out. Idle issues.
Old May 3, 2012 | 01:22 AM
G35LikeaG6's Avatar
Hey everyone. Cleaned my throttle body and combustion chamber today with some Mopar Combustion Chamber Cleaner. Everything went fine only now the car is somewhat revving by itself after I let off the gas and depress the clutch (as in when shifting between gears). Its also idling at about 1100rpm. I did an "Infiniti G35 Coupe Accelerator Pedal Released Position Learning", a "Infiniti G35 Coupe Throttle Valve Closed Position Learning", and also an "ECU reset procedure".
I thought I did the "Infiniti G35 Coupe Idle Air Volume Learning Procedure" but I guess it was done incorrectly.. Anyone have any experience with the same issues as me and a possible fix just incase the Idle Air Volume Learning Procedure doesnt work when I attempt it again tomorrow..???
As always all help appreciated !
Old May 5, 2012 | 03:46 PM
G35LikeaG6's Avatar
Problem solved. Did an Idle Air Volume Learning Procedure and also had a small vaccume leak where the top half of the plenum meets the lower plenum.
DEMoLITIoN
Interior
47
Oct 6, 2018 10:44 PM
BradMD_96
Oct 6, 2015 09:31 AM
the93owner
Oct 4, 2015 09:40 AM
vQFamily
Sep 30, 2015 01:17 PM
vamarris
Sep 26, 2015 12:56 PM
