Need Tires
Old May 7, 2012 | 08:57 AM
g35jdm's Avatar
Need Tires
i couldn't post under the wheel section, so ima post it here. i need 2 rear tires new or used to pass inspection by the end of this month. (245/45R18) they are the stock tires they came with the car. but i dont really car what brand tires they are i just need some new or used ones by the end of this month so i can pass inspection in june. i live in kennett sqaure, pa. i would rather keep it local but hit me up to see what you got.
Old May 7, 2012 | 09:23 AM
gary c's Avatar
An easy option would be to check the tire stores in your area for a pair of used tires to get you thru the inspection....shop around.
Gary
Old May 7, 2012 | 10:18 AM
herrschaft's Avatar
You can find a cheap set of tires at any tire store. 2 crappy tires should be inexpensive whether they're new or used.
Old May 7, 2012 | 01:16 PM
thepro78's Avatar
What type of inspection requires stock tires?
Old May 7, 2012 | 02:40 PM
gary c's Avatar
It's probably more about wear than the tire size. Some states require a specific tread depth in order to be safe on the highway and pass the test....Gary
Old May 7, 2012 | 08:45 PM
ohsixmtee's Avatar
OP, check out bestusedtire.com. They're out of Allentown and are really cool to deal with. There's also L&M tire and wheel in Abbottstown. Both are good sources for used tires, just don't let L&M over charge you. They tend to think used = new sometimes.
Old May 8, 2012 | 05:09 PM
VMRWheels's Avatar
If you're looking for used tires just hit up Craigslist or even the classifieds on the forums. I know lots of people that have done that in the past.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
