Issues with Slip/VDC
Old May 9, 2012 | 12:19 PM
aa2033's Avatar
Hey guys, I'm having issues with my Slip / VDC lights coming on around corners. I'm not sure if it's my front that's rubbing when the car flexes to one side, but I don't think it is. I got my alignment done and everything is great except my front camber which is around -1.8 on both sides. I upgraded to 19's from 18's, got wider tires, and lowered myself a good amount all around. I had been reading about a steering angle sensor needing to be reset? has anyone else done this procedure? did it fix this crap?
Wheels are 19x9.5 +17 F w/ 245/35/19. and 19x10.5 R w/ 275/35/19
This is the ride height, it doesn't seem to be low enough for me to rub around corners. (I tried to keep function :P )
Old May 9, 2012 | 12:25 PM
PAIXAO's Avatar
Your tire size differences are greater than 3%. That is probably the source of your problem right there.
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
