Converting to Brembos ! HELP
Old May 12, 2012 | 02:42 AM
jutn35's Avatar
G35 Coupe
Exclamation Converting to Brembos ! HELP
I just bought front Brembo Calipers and I want to know what do I need to complete this vision. I heard its straight bolt on to Non Sport Brackets.
This is what i added up.
Front Brembo Rotors
SS brake lines
Front Brake Pads
BREMBO CALIPER SEALS REBUILD KIT- OEM
Spacers maybe ?
Is there anything im missing ?
Im going to powder coat them so ill do the rebuild kit after theyre done.
Im going to do a black and white paint scheme like the 300zx
and will these fit my OEM 17inch 6 spoke rims Picture Below >>>>
Old May 12, 2012 | 07:20 AM
Swiftyk6's Avatar
Oem brembos will fit the oem 18 and 19's and aftermarket rims with a decent offset
Old May 12, 2012 | 09:08 AM
gary c's Avatar
My main concen w/b those wheels fitting, MT coupes that came with Brembos wear 18" rims not the 17" you posted....Gary
Old May 12, 2012 | 09:18 AM
JaE35's Avatar
Moderator
G35 Sedan
http://my350z.com/forum/brakes-and-s...bo-brakes.html
Everything you need to have and know is there
Old May 12, 2012 | 09:19 AM
JaE35's Avatar
Moderator
G35 Sedan
And stock 17's won't clear without spacers
Old May 12, 2012 | 05:35 PM
jutn35's Avatar
G35 Coupe
Ok so with spacers i can clear it then , how many MM ^ ?
Old May 12, 2012 | 05:44 PM
jutn35's Avatar
G35 Coupe
Found something !
https://g35driver.com/forums/wheels-...questions.html
Old May 14, 2012 | 05:37 PM
jtierney78's Avatar
Let me know how it turns out for you after theyre painted and installed. This is something I plan on doing in the future as well but Im sitting on factory 18's.
Old May 15, 2012 | 04:22 AM
jutn35's Avatar
G35 Coupe
BAD NEWS , i found out theyre from a 2004+ sentra that came witht he brembo package, they may look similair but the bolt pattern wont match up to the G35
FML , see if i can work around it or sell them
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
JustinMKN1
Sep 18, 2015 03:40 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
