Coolant pipe help
Old May 17, 2012 | 01:45 PM
blackout2277's Avatar
Coolant pipe help
Ok guys so my waterpump is finally complete just need to get the air bubbles out of the system. Anywho while working on the pump I noticed a hard line coming from ext to the driver side of the radiator is just cut off and when I was bolting my ac compressor back up I found that two hard lines go into there and I had one that came up from the backside of the motor and the other spot was empty. I knew when I got the car the ac didn't work. I'm just assuming that the cut line by the radiator is supposed to go into the compressor? Can anybody provide a pic of where that pipe goes? And also where would I buy one at? Thanks in advance
Old May 20, 2012 | 09:20 PM
Bump anybody???
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
9tray turbo
Sep 29, 2015 10:22 PM
