Bridging the gap..... The wheel gap that is!
Old May 22, 2012 | 09:52 PM
Jahaaji's Avatar
Fellow G lovers
I'm in the process of changing my wheels and after reading different threads regarding wheel size, offsets, aggressive vs non-aggressive I'm totally indecisive and not sure if I got the right wheel setup
My current wheels are 18's (225/40f & 245/40r) not sure what the offset is but the wheels are almost in the engine & trunk. Wrong wheels by the previous owner
I bought 19's 19/8.5 +15 in the front & 19/9.5 +20 in the rear. Tires, 245/35f & 275/35r
I'm not a fan of anything too aggressive and with the specs I have I should be ok. Just wanted get opinions on my setup as a daily driver
Will I poke out at all? Do I need spacers? I'm really looking for a flush look with my fenders
Old May 22, 2012 | 09:55 PM
TORETTO's Avatar
what do you mean your wheels are almost in the engine & trunk lol
Old May 22, 2012 | 09:59 PM
Jahaaji's Avatar
Tucked way inside the fender lol. From the side you'd think I'm driving on my rotors!
Frankieg35's Avatar
Haha!!
Old May 22, 2012 | 10:01 PM
TORETTO's Avatar
fronts will be tucked in about 1.2 inches.
rears will be tucked a good amount as well (i think)
Old May 22, 2012 | 10:03 PM
Th3R3dStar323's Avatar
i think he means this
Old May 22, 2012 | 10:06 PM
Jahaaji's Avatar
I'll take those wheels over what I have now! Lol So I guess I might need spacers to be flush?
Old May 22, 2012 | 10:07 PM
TORETTO's Avatar
Probably 25-30mm all around.
Old May 22, 2012 | 10:10 PM
Are you going to be "hella"?
Old May 22, 2012 | 10:15 PM
Jahaaji's Avatar
Ok.... I'm still kinda new and trying get upto speed with the lingo but what Does "hella" mean? Lol
Aggressive?
Old May 22, 2012 | 10:19 PM
Condog's Avatar
Get the biggest spacers you can buy
Old May 22, 2012 | 10:22 PM
jk, hellaflush is aggressive/stretched/neg camber basically
Old May 22, 2012 | 10:25 PM
Jahaaji's Avatar
Lol not like the convertible Honda civic
So spacers it is...... What offset should I have gotten?
Old May 23, 2012 | 02:55 AM
Eno's Avatar
Eno
Your sizes sound like mine- I ended up with a full inch on the front and half on the rears.
Regardless i will pass on some advice I received- and that was to take a stack of washers and put them on first- then put the wheels on... Just for fit. Once you get the fit you like, measure the washers. Buy said spacers-
That worked for me- just make sure youre at the stance height you want... You'll have to buy another set if you decide to drop or raise... It changes the fit.
Old May 23, 2012 | 09:21 AM
gary c's Avatar
Do you have the new wheels on your coupe yet? Post pic, your offsets sound about right without getting to "Trendy!"
Gary
