relocating cruise controls?
May 23, 2012 | 02:48 PM
Has anyone relocated their cruise controls to someplace other than the wheel? I would like a smaller wheel for the track, but still want cruise control for the highway.
Reply 0
May 23, 2012 | 04:04 PM
jUST asked this question about an hour ago because I'm going to be doing the same thing. What I've learned is that the cruise control is basically just a 6 wire connection (2 for the 3 functions). You can build a simple switch set for on/off and set/reset and place it wherever you'd like. I have yet to actually explore that, but it sounds like solid info.
Reply 0
May 24, 2012 | 01:49 AM
funny I must have skimmed over your post lol
Well I was thinking of taking the switch set out of the wheel and mounting it someplace as long as it has wires running to it inside the wheel that I can extend to bypass the steering wheel rotor. I havent taken the wheel apart to see if its wired or if its a big circuit board. Was hoping someone here has tackled this already. If you figure anything out lemme know and I'll do the same for you. Might be a little while before I try this though.
Reply 0
