Lower Control Arm Question
Old May 28, 2012 | 03:29 PM
RubensG's Avatar
so my lower driver side control arm is bad..i can hear it rattle on bad roads and when i step on the break do i have to get a whole new control arm or can i just buy the bushing?? Thanks in advance
Old May 28, 2012 | 03:34 PM
Snakes' G's Avatar
You can get new inner bushings.
Old May 28, 2012 | 03:52 PM
RubensG's Avatar
Thanks! so the only reason i would need a whole new one is if it was cracked or something right
Old May 28, 2012 | 03:55 PM
Snakes' G's Avatar
Yea, pretty much or bent. Also, I think I replaced mine with white lines. I think a few companies make replacements. Replace the bushings on both sides while your at it.
Old May 28, 2012 | 04:15 PM
RubensG's Avatar
thanks again i was about to order a whole new set $400
Old May 28, 2012 | 05:03 PM
g35dalf's Avatar
Is it a bushing or the ball joint? If it's the ball joint, I think you can only buy the whole control arm - I don't think they sell ball joints separately... and I'm pretty sure you can pick one up for less than $400 - is that price quoted from a dealer?
Edit: I just checked at RockAuto and the most expensive control arm (ACDelco) is $130. Even a Moog or Raybestos is only $110...
If it's the bushing then they're $16.
I checked a 2006 - not sure what year your car is.
Edit #2: they also sell ball joints separately so I guess you can change them out. It's $43.
GL
Old May 28, 2012 | 05:12 PM
RubensG's Avatar
Im not sure im going to have to get it checked out the 400 is oem brand new off ebay for 2 of them think I need both
Old May 29, 2012 | 02:03 PM
Mr. Brett's Avatar
Definitely just replace the bushings with new ones.
The OE design on the inner bushings is terrible...just Nissan cutting corners to save money. I bought a set of Whiteline's bushings to replace them with...$50 shipped off of eBay.
Before I put the new bushings in, my car's front end sounded like it was going to explode over potholes and bumps on the highway. The Whiteline bushings have turned the rattles into dull "thuds" on the highway.
Old May 29, 2012 | 03:06 PM
RubensG's Avatar
Thanks guys ill have them checked out and fixed yeah I feel the same way when I go through bad streets I feel like my wheel is ganna fall off and its so emberrasing too ahahha makes noise all the time
Old May 29, 2012 | 03:35 PM
CLEANBS's Avatar
I have the whiteline LCA bushings, pretty noticeable steering feel
Old May 29, 2012 | 06:06 PM
RubensG's Avatar
noticeable feeling? good way or bad way?
Old May 30, 2012 | 04:53 AM
CLEANBS's Avatar
good!
firmer
Old May 30, 2012 | 09:46 AM
Mr. Brett's Avatar
^ Right.
With the Whiteline LCA bushings in, the front end felt snappier and more responsive to steering input. You'll pick up a little bit of road feel, too, just as a heads up. That never bothered me, though.
Old Jun 9, 2012 | 03:05 AM
Max_Powers's Avatar
I guess I'll ask my question here, how did you make sure that it was the front lower control arm bushing? Looking at pics online, like on the DIY bushing replacement, the arm doesn't stay centered, it moves to the side when bushings are bad. But looking at my arm it looked centered.
The symptoms I see are a clunk sound when going on an incline such as a driveway and certain bumps and the car being a bit wobbly over potholes.
Does that sound like the lower control arm bushings need replacing?
Old Jun 9, 2012 | 08:58 AM
Snakes' G's Avatar
That sounds more like a compression rod bushing. Mine used to clunk all the time going into driveways and what not until I replaced them.
