Question about lowering
Old May 30, 2012 | 01:11 AM
S_johnston69's Avatar
Im thinking about either getting Tein Type S that has a 1.5" drop or B&G S2 Sport Springs which have a 1.4" drop. Am i going to need to get either a front camber kit or back or both? thanks for the help!
Old May 30, 2012 | 01:14 AM
bluedevils95's Avatar
I like the tein better. You will need to get a camber kit if you want to be close to spec
Old May 30, 2012 | 01:20 AM
front,rear, or both?
Old May 30, 2012 | 01:37 AM
DrewDrew's Avatar
both. front's have no adjustment. oem rear arms are only good for about an inch drop.
without them, you'll be around -2.2* camber.
spc front and rear kits will do the drop. be prepared to pay quite a bit for the front kit though. don' forget to get the spc toe bolt kit as well and elongate your toe holes. otherwise you're gonna chew through your rear tires quickly.
Old May 31, 2012 | 11:25 AM
Jhambor's Avatar
Tein all the way! Type S will certainly require front AND rear camber kits. Type H, you can get away with just the rear camber kits. I personally have the Type H, SPC rear camber kits, and 20mm spacers all around on the oem 19's. It's perfect IMO and still mostly driveable around town...speedbumps, curbs, etc.
Old May 31, 2012 | 11:30 AM
Ye_Budyy's Avatar
I'm runnin tein s-tech on my G I love them! Currently no camber kit though but I'm gonna put one in pretty soon...especially in the front...my tires get eaten up pretty bad
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
