Constant squealing from right front area
Old May 31, 2012 | 01:04 AM
Darkstar752's Avatar
Hi guys,
Picked up a 06 black/black G35 coupe recently with 60k miles. I love it! Anyway, there's only a couple minor problems with it, so I'll just list them all but the thread title has the main problem.
1. There is a constant squeal from my brakes. It sounds like as the rim is rotating, about 50% of something moving is making contact, basically like old brakes on a truck or bus will sound, not a constant tone but as it slows down you hear it. However, mine happens nearly all of the time. Does anyone know what this is? It's going into the shop on Friday and I would like to be able to give the mechanic an idea of how to fix it.
2. The door light that illuminates when the door opens to shine on the ground is out on the driver's side. What type of bulb does this take?
3. The driver's side window squeaks when all the way down, but only when it hits a bump. Very minor annoyance, is this an easy fix?
Did some quick searches but most of the threads are old with broken picture links. Thanks in advance!
Old May 31, 2012 | 07:38 PM
SFG_35's Avatar
Originally Posted by Darkstar752
Hi guys,
could be your rear brake pads are low. take a look at it before the mechanic charges you an arm and a leg just for pads.
Old May 31, 2012 | 08:57 PM
Thanks man, I'll check it out. I had it inspected 8 days ago before I bought it, and they said half on the front and a bit less than half on the rear. Tomorrow is the state inspection since I didn't buy it in my home state. Sound definitely seems to be coming from the front though.
tiguy99
Mar 1, 2016 11:42 AM
rping
Jul 26, 2015 09:53 PM
newg37
Jul 26, 2015 09:32 AM
bickfordbft
Jul 20, 2015 07:57 PM
