About To Be a New G Owner! Need Some Help
Old May 31, 2012 | 04:47 AM
Michaelh90's Avatar
So for the last month i've looking into buying a 03-05 G35. I found a 05 6MT that has 100.200Miles on it. The cars exterior and interior looks in pretty good shape from the pics.. Today im going to check it out at the dealer.. I been researching on how to find out if it has a OC problem.. How can i tell if it has a OC other than oil leaking at the bottom.. And testing the car at a infiniti dealer? What other things should i look at? It just reach 100k miles so woukd there anything that needs to be change? Any any maintence. I just want to buy the car and pay for it the loan the fastest i can and then start modding it or doing the maintenances. =] thanks in advance !!
Old May 31, 2012 | 06:28 AM
jusrushem's Avatar
valve cover gasket leaking into cylinder #6 especially, cv boots cracked, thats the main 2. i have heard over 80% of the new owners have the problem
Old May 31, 2012 | 08:04 AM
Michaelh90's Avatar
Ok thanks ill make sure to look under the valve cover. Definetely dont want to get a OC problems. The carfax is clean, only has one recall about a airbag sensor that was fixed..
Old May 31, 2012 | 08:43 AM
gary c's Avatar
There is no real way to tell if the '05 you're looking at has OC issues which is caused by poor quality piston rings. Sure there are other ways to lose oil like the valve covers but that won't require getting a new motor. Maybe looking at a coupe with far less miles would be a better idea than one with 100K miles on her clock. Often it's better to pay a little more now than a lot later....Gary
Old May 31, 2012 | 08:54 AM
Michaelh90's Avatar
I have been searching for a while and there are not that many 6MT on sell around. I saw one with 95k miles but the engine was swap due OC so the engine only had 33K on it for $12.5k.. And the one im looking with 100k miles for $ 10k
Old Jun 1, 2012 | 03:50 AM
jusrushem's Avatar
look at this bro
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
NailBomb
Oct 28, 2015 07:53 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
TNRocker
Sep 21, 2015 08:36 AM
