the door on my G shocks me every time i get out of the car..
Old Jan 12, 2005 | 01:33 PM
ryno's Avatar
rubber mats here
Old Jan 12, 2005 | 01:35 PM
ck700sl's Avatar
Hey I can help you guys! I found a way to eliminate the static shock when getting out. Before opening the door and getting out, take your infiniti key out of the ignition, then rub your thumb and index finger in the metal part of the key, then while still holding the metal part of the key, get out of the car. Sounds involved but its all just holding the metal while getting out.
I dont really know the mechnics of why it works, but it works. Havent been shocked since!
Old Jan 12, 2005 | 03:31 PM
didit70's Avatar
the easiest thing to do is to spray your carpets with static guard... this will definitely fix your problem
Old Jan 12, 2005 | 03:59 PM
G35_coupe_6MT's Avatar
I get shocked too (currently) and I live in Florida. It has to be the weather. During summer, there is no shock at all.
Old Jan 13, 2005 | 03:20 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by ryno
i swear that every time i get out of the G, when i reach to shut the door i get shocked. now comes my perhaps stupid question.... Does this mean i have a bad ground and should install the grounding kit? i've contemplated getting a wire kit, but have read mixed reviews. maybe i have a bad ground and should pull the trigger. thoughts? anyone else have a "shocking G"?
Don't think it has anything to do with grounding within the car itself, but it does have to do with the ride grounding to earth.
You need to hang a small wire or grounding strap from the chassis to ground if this is a big issue. You could hide it under the car so it's not noticed.
Old Jan 13, 2005 | 04:07 PM
s4m222's Avatar
just touch something else before you get out? should dissappate the built up static... . im not a science guy but i know there is an easy way around it...
Old Jan 13, 2005 | 04:58 PM
WRAH's Avatar
WRAH
I find this topic funny... Does it hurt that much?
Old Jan 14, 2005 | 01:35 AM
romanwarrior's Avatar
Static Electricity
If you live in Southern California, Nevada, Arizona, or Utah you will get an "electric shock" when you touch metalic objects - that includes your G35. This is common in dessert regions in the winter when the air is dry. It's just static electricity.
To avoid getting "shocked" use your hips to close the door after you get out of the car. Clothing seems to be a bad conductor of electricity. That's what I do anyway. Hahaha!!!
restrada
Aug 6, 2015 01:44 PM
JMSABO
Aug 4, 2015 11:58 AM
apintojr
Jul 23, 2015 10:52 AM
cyrus32
Jul 18, 2015 06:22 PM
