Car wont start 2007 g35 coupe 5AT
Old Jun 7, 2012 | 05:42 PM
matt1028's Avatar
A friends G just stopped starting. So I went and checked it out and it wasnt the battery. So I assumed the starter since I would not hear any clicking when turning it over. So I had her in the car trying to turn it over while I knocked on the starter with a wrench. It started; So I assumed it was the starter. I had her take it to a shop to get it fixed where they turned it on and off seven plus times no problem. But she had them replace the starter anyway. After replacing the starter they had problems getting it started. So she gets it back and drives it for a day and then again it wont turn on. All the lights come on, fuel pump kicks on, but there is no click or anything from the starter. recently she went to a small car audio place and had a sub and amp hooked up to her stock radio before the car stopped working. She told me this so I took it apart and looked at it to see how they ran the wires. They tapped into one of the ignition wires (White/ grey with black stripe i believe) in the steering column for the remote wire on the amp. Do you think this can mess with the cars immobilization system and not allow it to start. Also she said the check engine light has not come on, but even though it hasnt could it still be throwing codes I can read with the scanner. Any help would be great. Thanks in advance.
Old Jun 8, 2012 | 12:45 PM
Ad3l_06's Avatar
I had similair probleme wit my G after changing the starter taking out the sub and blabla i rececked the battery one of the cells was finish changed the battery and everything wass good
chinee
Jun 10, 2024 07:48 PM
R350k5
Oct 1, 2015 08:41 PM
Frostbite91
Jul 27, 2015 05:25 AM
kenthung
Jul 21, 2015 05:56 AM
