JDM steering wheel swap
Old May 15, 2013 | 09:35 PM
ExposedZombie's Avatar
Hey 350Gt you mind elaborating a little more on how exactly you swaped the air bag covers?
Old May 15, 2013 | 09:38 PM
Im trying to do the same thing to my 03 g35. So yea 350gt could you explain to me what im going to need to do?
Old May 15, 2013 | 09:41 PM
Hey idk if my other replys worked but umm yeah lol 350gt could you tell me how to swap the cover? I'm just really scared.
Old May 15, 2013 | 09:53 PM
350GT_'s Avatar
It's basically like what k67p67 said:
Originally Posted by k67p67
It's an easy job. You can definitely handle it by yourself. Be sure to disconnect the negative battery terminal first. Need to get a Torx T-30 Security bit (not a regular Torx bit). A few flat head screwdrivers are handy to keep the tabs apart while you try and separate the cover from the module. You'll know what I mean when you see it. Also, be careful disconnecting the plugs so that you don't break them.
I had my friend whom I bought the airbag from do it for me; it was installed also installed on his car. The installation appeared to be really easy based on my observation of the whole process (he did everything). Also his car's an '04 and mine's an '06 so I don't believe there would be any issues since yours is an '03.
If you're scared or just not confident enough to take it on then just take it to a shop. I've had one shop tell me that they'd have to take EVERYTHING apart which isn't true.
On the sides of your steering wheel there are two screws (not normal ones; they require that T-30 security bit mentioned in the quote). Once those are out and the plugs are disconnected then the airbag should slide right out. You basically just have to reverse the steps in order to install it.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
realtalk21
Jul 20, 2015 09:07 AM
