Next performance part?
For power, get the MREV2 if you have a manual, just a spacer if you have auto. HFCs would be next on my list, but I'd leave the cats to stay street legal. Get tuned with the Osiris, and get a 100 octane map made while you are at it. I'd say a good short shifter should be mandatory if you have a manual, along with a heavier clutch and lightweight flywheel. A higher final drive ratio will help with the acceleration whether you have auto or manual, and almost any kind of LSD would be better than the one that comes with the G. If you have an auto, I'd suggest the TransGo valve body upgrade kit for your transmission. As for handling, sway bars are a must, good struts would be next, and tie bars would be the least you'd want to tighten the chassis.
There has been a bit of debate about the crank pulley with the VQ motors as some say the crank pulley will throw off the Harmonic Balancer. I don't have any personal experience with this as I've never cared for the minimal gains you can get from this.
A good valve body upgrade like the TransGo will make your car shift faster and better, which means a world of a difference when you put it into manual mode.
Ohhhh okay is there that much of a difference? Also it shoudlnt make a difference for install eve though mine is AWD right? Why do people say the install is so pricey? Is it a PITA?
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
