Do fuel injectors increase HP?
Old Jun 23, 2012 | 05:54 PM
viktor04g35's Avatar
I am new at this but so fuel injectors increase HP?
Old Jun 23, 2012 | 06:50 PM
Killerzracing03's Avatar
No unless you have alot of mods, and I mean alot on a NA build or your boosted.
IDk how much stock injectors support, but I think it has a little bit of overhead.
Old Jun 23, 2012 | 07:06 PM
Eno's Avatar
Eno
Bigger Fuel injectors will allow for more hp - but unless you're going FI I'm doubtful that any amount of bolt on intake and exhaust mods (and tune) would require higher flow than what stock can provide.
Old Jun 23, 2012 | 07:17 PM
seymore4's Avatar
m56
Only if you're running out of fuel on the stock set up... Will never happen on a stock setup, plus bigger injectors will require a complete retune to get the engine to run correctly
Old Jun 24, 2012 | 11:14 AM
tylerxfire's Avatar
injectors do not give you more power on their own, they allow you to make more power when you are running out of fuel. You will have to tune for bigger injectors
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Hogbone
Sep 28, 2015 06:44 PM
