need recommendation on camber kit
Old Jun 27, 2012 | 02:17 PM
G-35's Avatar
my mom has a stock '05 g35 coupe and a couple of months ago i ordered her new tires. well only after a few thousand miles, the front tires are cuppling(again). i've had to deal with this issue for years. the last time i looked into a camber kit for the car, there wasn't much available years ago. however, now i see that there are quite a few companies offering these kits.
can you guys give me your recommendation on what's the best camber kit out there that will get the car aligned to specs that will help avoid tire cuppling? the car is stock height. the rear tires wear pretty good, but the front is another story.
Old Jun 27, 2012 | 02:37 PM
k67p67's Avatar
Considering your mother's G is not lowered, the treadwear problem is most likely related to worn suspension component(s). Don't waste $ on camber arms.
Quick explanation
Old Jun 27, 2012 | 02:39 PM
JaE35's Avatar
Moderator
G35 Sedan
could be a blown tie rod or bushing failure somewhere...get on an alignment rack and have it checked out
Old Jun 27, 2012 | 02:56 PM
G-35's Avatar
Quick explanation
this has been an issue since new. it would either wear the inside of the tire or cupper. i've had numerous alignments done and they would always tell me that the factory doesn't allow enough adjustments to fix this issue. after the stock struts wore out, i upgraded to tokico adjustable. however, it's got about 70-80k on it now so maybe it's time to get new struts again.
i guess i'll have to take a closer look at all the components underneath.
Old Jun 27, 2012 | 06:57 PM
gary c's Avatar
Take your G to an independent brake/alignment shop and have the suspension checked out, you have other issues rather than adjustable a-arms. If you're not lowered you shouldn't need em....Gary
Old Jun 27, 2012 | 09:28 PM
VMRWheels's Avatar
+1
A dedicated shop will be able to figure out the route of the problem. If the car isn't lowered camber arms are not going to help.
Old Jun 28, 2012 | 01:04 AM
g35sleeper123's Avatar
might be time for new shocks/bushings
paolojericho11
Sep 11, 2015 07:08 AM
NohoG35revup
Aug 22, 2015 12:13 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
