Any differences between coupe and sedan engines?
Old Jun 28, 2012 | 02:48 PM
Michaelh90's Avatar
Originally Posted by dofu
revup motors weren't the only VQ motors with OC issues.
yea i just found out the hard way =( i dont know where my oil went..
Old Jun 28, 2012 | 03:37 PM
partyman66's Avatar
Originally Posted by Michaeh90
ok ima check then but i dont think i want one of those rev up engines i dont want to have a OC problem.. so my engine blew up some how now i need a new one, what you guys think about this one overprice?
http://www.ebay.com/itm/120929273061...ht_5088wt_1166
or this one.. can i fit an ''X'' AWD in my G ?
http://www.ebay.com/itm/2006-INFINIT...#ht_500wt_1416
If you have 2 motors with equal miles on them and one is from an X while the other is from a RWD G/Z, go with the RWD one. An AWD drive-train adds extra strain to the motor because it takes more power to spin the AWD drive-components and wheels, so the motor may have taken more abuse under similar driving situations in a G35X vs a standard 2WD G35/Z.
Old Jun 28, 2012 | 03:53 PM
Michaelh90's Avatar
The first link is a remanufacture engine with "zero" miles im not sure bout it.. <<<<<any opinions?
True about the X AWD thanks. (out of my shpping list)
Old Jun 28, 2012 | 06:27 PM
Imperial1's Avatar
I have an 04 Coupe M6 and my engine burned oil... I had to get it replaced a few months ago. it's not just rev-ups.
There's a difference power wise between the 03-04 Coupe and Sedan engines aren't there? Coupes are rated at 282HP and sedans at 260HP.
Old Jun 28, 2012 | 06:34 PM
Michaelh90's Avatar
the sedan engines are cheaper for some reason...
Old Jun 28, 2012 | 06:55 PM
Eric@TCGMiami's Avatar
Because yards have no idea... (for the most part)
Old Jun 28, 2012 | 08:42 PM
Michaelh90's Avatar
lol i know i was telling them that they were the same and insist saying they wasnt.. btw since im swapping my engine what else should i get replace that its on the way? Spark Plugs, Timing Belt, water pump (Nismo?) Thersmostat, what else??
Old Jun 28, 2012 | 10:00 PM
I would do sparks for peace of mind along with thermostat. other than that you may never have to change timing chains, nor the internal water pump.
Old Jun 28, 2012 | 11:08 PM
crazynuts16's Avatar
do not buy from 123engine is the best advice i can give you right now.
http://www.la.bbb.org/business-revie...k-CA-100101056
http://www.ripoffreport.com/junk-dea...is-a-5826e.htm
http://lmgtfy.com/?q=123+engine+review
Good luck!
Old Jun 29, 2012 | 12:00 AM
faiz23's Avatar
Dude you got money to blow or just a nice credit limit on your card. Do your research before you go swiping your card on the world wide web and buy a POS engine with crap service. Check your local yards and check with carpart.com that links junk yard around the US to give you pricing and info. Buy something with a decent warranty and find out what is actually the history behind the engine (eg: sitting around forever, oil consumption, knocking, ticking, wrecked). I would scour through craigslist using a search like searchtemptest, ebay, junkyards, copart, carpart and even ask dealerships for where they get their reman/used engines from.
edit: DUHHHHH... Use common sense. If you can get a sedan typically it is driven by and older crowd and has less likely hood of being used aggressively. I would be looking at a 2005-2006 G35 Sedan RWD AUTO with low miles and long warranty. Next would be the 2006-2007 G35 coupe AUTO, and then 2003-2004 G35 Sedan Engine.
http://www.searchtempest.com/
www.carpart.com
http://www.moreofit.com/similar-to/c...ke_Crazedlist/
Rebuilt engine from decent specialty VQ shops with FORGED parts. You can call for custom quote using all stock parts or a decent rebuilt motor versus 123 self destruct engine.com
Engine packages are customizable to match your goals. Here are two samples of common configurations:
Stage 1 Short Block packages start at $2765 and include CP Pistons, Eagle Rods, ACL Bearings, machining, align hone, balance, blueprint and pro assembly!
Stage 1 Long Block packages start at $3690 and include the Stage1 Short Block, ARP L19 Head Studs, ARP Main Studs, Cometic Head Gaskets, Mill & Clean Heads and assembly.
Picture is revup but still an engine
http://my350z.com/forum/engine/51070...ur-engine.html
http://www.importpartspro.com/shblpa.html
http://my350z.com/forum/engine/47208...eeds-here.html
Old Jun 29, 2012 | 09:20 AM
Michaelh90's Avatar
Great help^^^ thanks guys ..
i just call a couple of junk yards and i ask for 2005 engine i got one pretty good 30K miles for $1000 off a 2005 g35 sedan.. i just want to make sure it fits into my 03 coupe because the guy told me there was two different ones made in that yr and ask me for a "production date".??
only reason im asking this cuz i dont want the shop where im gonna get my engine swap to have any complications like ecu or other things...
Old Jun 29, 2012 | 03:05 PM
dofu's Avatar
20 Year Member
The motors are all the same size, shape and they mount into the engine bay just the same.
vmcarbuyer
Oct 12, 2019 12:42 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
