German Castrol 0w-30 not available, what next?
Old Jul 17, 2012 | 06:40 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Jairen
I've used GC myself with great results. On my old oil consuming motor, it consumed less for some odd reason with GC.
I saw sale for it a while back at my local Pep Boys and stocked up big time.
autozone has those sales every month.
Old Jul 17, 2012 | 08:01 PM
saywat?'s Avatar
castrol edge is no good?
Old Jul 17, 2012 | 08:27 PM
joedaddy1's Avatar
try using 5w-30 M1 EP.. i've had good luck with it.
Old Jul 17, 2012 | 08:36 PM
PAIXAO's Avatar
I use conventional motor oil in my oil consuming G35. In 20k miles is has gone from consuming a quart every 400-500 miles to consuming 1/2 a quart every 2500 miles.
Old Jul 17, 2012 | 09:22 PM
gary c's Avatar
Originally Posted by djhiro
@ Gary, just wondering which Amsoil oil are you using. I know there is a thread on my350z called "VQ Oil Analysis" or something like that and only one of the Amsoil oils seemed to do the better than the others.
I've been using AMSOIL ATM 10w30 for the last 3 years along with either WIX or in the past K&N filters. It's possible if you used a 10W30 weight oil you might stop the OC issues you've been having, or even a 10W40. I used 20W50 Mobil 1 in my '92 Nissan 300ZXTT for over 125K miles without incident. That was before they changed their base....Gary
Old Jul 18, 2012 | 01:50 AM
Hiro's Avatar
Castrol Edge no good? I don't know...I'm wondering myself. They have the new Castrol Edge with Syntec 0w-30 and the numbers look almost identical to the GC 0w-30. Could it be the same oil in a new bottle?
Unfortunately, there are no Autozones where I live so that is not an option for me, but thanks for the replies.
@Gary...from reading I thought that 0w-30, 5w-30, and 10w-30, are basically the same once it reaches operating temperature? The first number only has to do with start-up. From my interpretation it seems like its ok to go down on the first number, 10w to 5w or 5w to 0w. Since this number only has to do with startup. The second number is more the weight or viscosity number. With that said, I'm not sure how going with a 10w-30 could help my problem if I'm using 5w-30. I can see maybe using the 10w-40, but in that case I might go with a 5w-40 or 0w-40 due to it getting cold where I live. Then again, regardless of the weights of oils you mentioned they are all in the acceptable ranges for your VQ. Maybe its just a matter of changing from Mobil 1 5w-30 to Amsoil or another brand of oil. Hmm...
Old Jul 18, 2012 | 02:30 AM
dofu's Avatar
20 Year Member
I'm not gonna argue GC but IMO - Motul > Amsoil
Old Jul 18, 2012 | 11:03 AM
Hiro's Avatar
Hey Dofu...thanks for your input. From the "VQ Oil Analysis and Info" thread at my350z.com it shows that Motul is one of the worst oils to use. Lots of wear and most of the findings were "all in the red" when compared to other oils.
Here's the link for those of you that are interested:
http://my350z.com/forum/engine-and-d...-and-info.html
Maybe Motul is better in some way, I just don't know if its great for your engines by the results of this test. Please chime in if I'm wrong though.
Old Jul 18, 2012 | 04:02 PM
joedaddy1's Avatar
hey.. Castrol Edge with Syntec 0w-30 should be the same as GC.. make sure it says Made in Germany in the back..
Castrol changed the names:
Castrol Syntec -> Castrol Edge w Syntec
Castrol Edge -> Castrol Edge w Titanium (this one burns like hell on the VQ)
Old Jul 18, 2012 | 05:29 PM
StanG35's Avatar
+1 on the castrol edge name change. Try checking local auto shops like autozone? I'm not sure what they have out there in the UK
Old Jul 18, 2012 | 05:36 PM
StanG35's Avatar
Seems as though it is really hard to get a hold of the 0w for this particular oil. I can't seem to find it anywhere but good news is they do have the 5w
Old Jul 18, 2012 | 06:39 PM
partyman66's Avatar
I'm pretty sure that they only make the German Castrol in 0W-30. If you're seeing some Castrol Syntec in a 5W-30, it's not the right stuff that we're referring to as "German Castrol".
Old Jul 18, 2012 | 07:26 PM
Hiro's Avatar
Thanks for the replies. There is Castrol at the American facilities here in the UK, but its in 5w-30 or 10w-30. No made in Germany or European Formula. Only the ones that said made in the USA.
Again, no autozones here. Even if there was an autozone or different store its way way expensive. We are talking $15 to $20 a quart. That's $75-100 in just oil without the filter. Just like everything else in the UK, things are not cheap. Also, if you have an oil consuming G that means you'd be using a lot more quarts at those prices as well. So if you guys had the choice to buy GC at those prices would you? Or would you go with the Mobil 1 0w-40, Pennzoil Platinum, or Castrol (Made in USA) oil priced at $6.50 to $8.00.
When I read the spec sheets from the Castrol site it talked about the USA line up of Castrol products. Could the new (Made in the USA) 0w-30 be the same as the GC that everyone is using? The specs look the same so that's why I'm asking. Thanks for you all the posts.
Old Jul 18, 2012 | 10:22 PM
Derek173's Avatar
Try to find used oil analysis (UOA) on bobistheoilguy forums, or send a used sample to bnlackstone for testing.
Old Jul 18, 2012 | 10:25 PM
  #30
saywat?'s Avatar
found it
