Help! Dash Alert not stopping.
Old Jul 23, 2012 | 12:06 AM
JRA's Avatar
JRA
Sounds like TPS alert but no TPS light and doesn't stop. No Dash warning lights at all. After taking the key out and opening the door it starts sounding. As long as the door is open it will ring continuously until door is closed. As soon as the door is reopened it starts again.
Old Jul 23, 2012 | 12:12 AM
Imperial1's Avatar
this is gonna sound silly but... did you turn off your headlights?
Old Jul 23, 2012 | 12:15 AM
JRA's Avatar
JRA
They are set to automatic.
Old Jul 23, 2012 | 12:38 AM
partyman66's Avatar
Put your headlights to the OFF position and see if it still makes the noise when you open the door.
It definitely sounds like the "Lights on/No Key" warning, based on your description of the problem..... except for the part about your lights being set to Auto mode. Did someone else drive your car? Maybe they switched it to manual or you accidentally hit the setting on the stalk.
Old Jul 23, 2012 | 09:31 PM
JRA's Avatar
JRA
You're right partyman. My girlfriend drove it and moved it to fog lamp mode. I should have thought of that but thanks for the tip.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
