Can you help me solve this problem?
Old Aug 2, 2012 | 12:14 AM
97prelude's Avatar
What's up guys. I'm ****ing pissed right now.
There was a wire blocking my CD loader so I figure I would take the radio out and fix it.
When I put the radio back in, my A/C controls and the Radio won't work. Everything lights up but the radio won't turn on and the A/C controls don't do anything. I did not disconnect the battery when I did this, so I am thinking I might have fried the units. What do you guys think?
Ugh I'm so mad right now Im fuming.
Old Aug 2, 2012 | 01:03 AM
06G35Coupe94's Avatar
Check all your fuses
Old Aug 2, 2012 | 01:08 AM
Mr. Brett's Avatar
1) Calm down
2) Calm down
3) Calm the f*ck down
Calm?
Okay
4) Go back out and re-check everything. Maybe you overlooked a plug, or pulled a connection loose reinstalling it.
Old Aug 2, 2012 | 01:23 AM
97prelude's Avatar
Originally Posted by Mr. Brett
1) Calm down
2) Calm down
Calm?
Okay
hahaha.. thanks. still pissed but calming down....
I rechecked everything, twice. I had the whole system put back together and then I took it all apart and check to see that everything was pluggin in... it was., I checked the fuses under the hood, everything is good. I tried disconnecting battery for 10 min, same issue.
I am having the dreaded A/C stuck on 75 issue, so i think i fried the board. I guess I gotta start scouring CL for new ****.
Thanks
Old Aug 2, 2012 | 01:38 AM
Mr. Brett's Avatar
Did you check the fuses in the kick panel?
Old Aug 2, 2012 | 10:32 AM
97prelude's Avatar
Yeah. All fuses are good
Old Aug 2, 2012 | 11:06 AM
Mr. Brett's Avatar
Well...not sure what else to try, then. Maybe a good wallop with your fist before you remove it? Just to make sure something isn't jingling around inside?
Old Aug 2, 2012 | 11:31 AM
Pepper's Avatar
Time to upgrade to DD unit with A/C controls combo.
Old Aug 2, 2012 | 04:42 PM
linedr89's Avatar
look for the fuse for the ac control unit and replace anyway.. see if it works...sometimes it will light up but be dimmer than the others.
Old Aug 9, 2012 | 01:04 AM
97prelude's Avatar
Just fyi. took it to a shop that does circuit board level repairs. they told me that the power supply for the stereo go shorted out. The dealer wanted $1,200 to replace the whole system. These guys fixed it and charged me $100.... works perfect now.
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
