Car vibrates when decelerating at high speeds
Old May 10, 2013 | 01:50 PM
LoSt180's Avatar
Bump old thread because my car is doing the exact thing as OP. Has nothing to do with braking, if accelerating at high speeds, car is smooth sailing, as soon as I let off the gas car shakes. Feels like it's coming from the rear and almost like an unbalanced tire. But if it was tire, it would shake at speed no matter what (I've had that problem before), this really only happens when decelerating at interstate speed (75-80 mph).
Old May 10, 2013 | 02:00 PM
PAIXAO's Avatar
We can look in to this tomorrow when I get there.
Old May 10, 2013 | 02:15 PM
dreamreality's Avatar
As mentioned in my reply, get your rims checked. I had a bent rim that was on the inside of the wheel and that's what caused it to shake when I decelerate.
Old May 13, 2013 | 09:11 PM
LongJohn6284's Avatar
I noticed the exact same thing on my trip through the mountains this weekend...only when i would let off the gas would it vibrate. even the slightest push of the go pedal and it would be smooth as silk...
really would like to know what is causing this...hopefully its just an easy fix becuase i dont feel like dumping money into a vehicle i just bought
Old May 14, 2013 | 08:47 AM
LoSt180's Avatar
Next step will be to try changing out my rear wheels. Just to confirm, did replacing your bent wheel fix this problem for you?
PAIXAO suggested I put the car in neutral, and it still shook but definitely was isolated to the rear. If it's not a bent rim, I'm going to start checking bushings.
Old May 25, 2013 | 05:17 PM
LoSt180's Avatar
Rims look good, but I noticed this when I had the car jacked up o_O
Strong hunch this might be my problem. Apparently the rear differential bushing is filled with liquid and it ruptured.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
rping
Jul 26, 2015 09:53 PM
vstypicals
Jul 20, 2015 10:55 PM
cyrus32
Jul 18, 2015 06:22 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
