suspension
Old Aug 24, 2012 | 02:33 PM
mammoth98002's Avatar
thanks for the info everyone bc racing seems like the route im gonna go since i cant afford stance
Posted from G35driver.com App for Android
Old Aug 24, 2012 | 02:36 PM
Big Booty Trudy's Avatar
Originally Posted by SoulGlo
i have the BC's - i like them, but hten again i don't have anything to compare them to. Smooth roads are fun. City you will creep around town. The G pretty much is a driveway queen
Do you know how low BC's go when maxed out?
Old Aug 24, 2012 | 05:19 PM
OBsessed's Avatar
Originally Posted by mammoth98002
oh i didnt notice... my bad what do you mean by rear setup is meh? like to soft to stiff? or what?
The BC rears don't go low enough or get stiff enough for my purposes. Have Stance GR+s on the way (true rear style coil rather than separate strut/spring).
If you're planning on going 2-3" already, I'd imagine that at some point you're going to want to go lower than that. Even if you don't and you "only" go 2-3" that's a pretty good drop. Save a couple extra bucks for the Stance setup, imo.
For reference, the Stance true rear GR+ is costing me less than $300 more than what I got my BCs for.
Old Aug 26, 2012 | 01:12 AM
SUMATIC's Avatar
if you wanna go low you should go with stance gr+. i got em on my coupe. and im LOOOWW, i got an inch half clearance under my car. and got more room to go lower if i wanted to. the ride is stiff. havent used BC coils before but i heard they could go low but some people say otherwise. the gr+ is about the same price range as the BCs maybe a lil more.
Old Aug 26, 2012 | 02:25 AM
What's the best price y'all find stance coils for? Best I've found is 1200 shipped
Old Aug 26, 2012 | 02:32 PM
i did research you can get bcracing standard which drops it 2.5 inchs max or you can get the extreme drop which is 4 inches you also have a choic of 8kg springs all the way up to 12kg
Old Aug 26, 2012 | 04:44 PM
Thanks
Old Aug 26, 2012 | 04:50 PM
Thanks
no problem ill post the website in a few
Old Aug 26, 2012 | 05:45 PM
OBsessed's Avatar
For what it's worth, unless this has changed in the last year or two, changing out your spring rates or any other options will add to the cost. I still think you'd be better off looking into Stance based on what you stated as your drop goal earlier.
You're also, as far as I remember, getting a progressive spring rather than a linear spring.
If you do go with the BCs I'm sure you'll be fine, they aren't a bad setup. They just end up a little limited if you try to slam it.
Old Aug 26, 2012 | 05:49 PM
OBsessed's Avatar
I probably should have asked this earlier too, what size wheels are you going to be running? I was fine with my 20s with a mild offset (10.5/9.5 +5) but stepping down to more aggressive 19s created some problems.
Old Aug 26, 2012 | 06:03 PM
right now im on stock wheels but i plan on going with a 19x9.5 +22 front and 19x10.5 +12 rear. but the rims and tires are down the road. here is the website i found the info for BC racing coilovers
http://www.flushstance.com/bcracing-...s/details-faq/
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
