Driving with very low oil for 3 weeks!?
Old Aug 27, 2012 | 03:39 PM
GDriver05's Avatar
So I picked up my 05 Coupe 55AT about 3 weeks ago. I checked my oil yesterday and it was right up to the low mark on the dipstick. I added a quart of Mobil 1 synthetic oil and its at the half way mark now. I'm planing on taking it to get an oil change asap, buts was any damage done to the engine driving it which such little oil? It runs fine and there no ticking or anything. The engine has 57k miles on it
Old Aug 27, 2012 | 04:11 PM
dx3's Avatar
dx3
There's no real way to tell, but I highly doubt it. Low oil, while low, just means some needs added (although my main concern would be more as to why it is low than what damage you may have caused.)
Old Aug 27, 2012 | 04:50 PM
dofu's Avatar
20 Year Member
Oil consumption is an ongoing battle for these VQ motors. You can find a lot of info on that topic with a quick search. Until you figure things out, I wouldn't suggest driving around with your oil pan half full as driving around without enough oil will cause abnormal wear on your bearings, and once those are shot, your motor is done for.
The only advice I have for you is to change your oil regularly, and avoid Mobile 1. Castrol Syntec is popular on these forums because it's good and protects your motor well. You'll hear people talk about some special German Castrol or whatnot, but the regular Castrol Syntec you can find in stores is just fine.
my350z - vq oil analysis and info
Old Aug 27, 2012 | 09:01 PM
AuAltima3.5's Avatar
I used synthetic in my VQ Altima and found it to be consumed MUCH faster than dino oil. Just my experience. I run castrol GTX in the G every 3k.
Old Aug 27, 2012 | 09:53 PM
rsingerG35's Avatar
I use Castrol Edge(Syntec) with great results. Synthetic is thinner and if you have leaks it may leak more.
Muski_G
Dec 1, 2023 11:11 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
ClwMike
Jul 23, 2015 12:55 PM
